Some washing machines have a mechanical/cable release hanging down underneath, perhaps behind the kick tray thing. the cable is attaches to the pulley at the back and it needs to push against the belt squarely to enable the door to open, otherwise, (after making sure it is unplugged) put you hand down behind the front fascia and lift the moveable part of the doorlock. This will not fix the problem but it will open the door.
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Make sure the pump has pumped out all the rinse water. If not cycle washer to 9 and pump water out. Push door button and it should open, if not it is the electrical door switch.
creda aqua wave 9.5kw electric shower, no hot water, you can here clicking inside the housing as if...
(More)
creda aqua wave 9.5kw electric shower, no hot water, you can here clicking inside the housing as if the motor or solenoid are trying to engage? something was replaced about a year ago to cure the same fault but it has gone again, I regularly clean the head out and make sure no other water device is running to avoid low water pressure etc
my washing machine just stop n the drum isnt even spinning, the waters coming through, but thats all...
(More)
my washing machine just stop n the drum isnt even spinning, the waters coming through, but thats all it does please help
