Question about Alpine TDM-7543
Wiring on tape deck Alpine tdm-7543
Please send me detail of the wiring of the cassette head. There is 5 pins/wires - left, right, ground other?? for the Alpine tdm-7543
    Champion:
  • 277 Answers
Hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Posted on Mar 21, 2006
SOURCE:
I have a question i have a alpine cda 9847 i color couted the wires and still no power on the unit in the car checked fuses not fuses is the wireing wrong? i even tryed to put the yellow onto the red and...
Confirm this wiring for 2000 Nissan Altima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Radio Power Antenna Trigger Wire: Green/White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4′ x 6′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
Hope helps.
Sep 26, 2011 | Alpine CDA-9847 CD Player
Am wiring my alpine car stereo back to my old car , unfortunately i dont know were to connect the wires , the labels on the wires somehow got cut when i kept it in storage , need help figuring were the red...
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Alpine TDA-7563 Cassette Player
Wireing diagram to hook up amp sub and 4 speakers
Here's the color codes for the wires.
Blue=power antenna
Blue/white=remote turn on for amp
Red=ignition
Yellow=battery
Black=chassis ground
Grey=right front (+)
Grey/black=right front (-)
White=left front (+)
White/black=left front (-)
Violet=right rear (+)
Violet/black=right rear (-)
Green=left rear (+)
Green/black=left rear (-)
RCA Connections:
Red=right rear to amp
White=left rear to amp
And that should be all the wires. Good luck!
Sep 26, 2010 | Alpine TDM-7582 Cassette Player
Need a wiring diagran for a alpine 7903
This is a pull-out deck, and should have the wiring schematic right on the chassis.
If it is illegible, you can use the standard wiring to wire it up as follows....
Yellow: Constant 12V Power
Red: Switched 12V Ignition Power
Black: Ground
Orange: Dimmer
Blue: Remote and/or Power Antenna turn on
Green/Black: Left Rear +
Green: Left Rear +
Purple/Black: Right Rear -
Purple: Right Rear +
White/Black: Left Front -
White: Left Front +
Grey/Black: Right Front -
Grey: Right Front +
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2010 | Alpine Car Audio & Video
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
I need the wiring dia. for alpine 8020
If the alpine 8020 is a deck(head unit) the wire diagram is as followed:
Red: Accessory
Yellow: Constant Power
Black: Ground
Orange to orange/white is a illumination or dimmer wire.
White: front left speakers
Grey: front left (white black and so on usually the negative on the speaker connections)
Purple rear left (purple black = neg)
Green: Rear Right
And if a video deck(light green is park brake)
(which is usually just a ground) so legally it needs to be on your park brake but can be grounded to make it work.
Speakers? (Terminals larger one is positive, smaller one is negative) Place capacitors on if needed to filter out and clear up bass
Hope this helps couldn't look uo what a alpine 8020 was..
Dec 10, 2009 | Alpine Car Audio & Video
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
I need the factory wiring radio color codes to a mazda 626 99 es so i can hook up my new alpine deck
Hi
The wiring color codes for 1999 Mazda 626 are--
Constant 12V+ Blue/Red
Switched 12V+ Blue/White
Ground n/a
Illumination Red/Black
Dimmer n/a
Front Speakers 6" x 8" Doors
Left Front (+) Green/Orange
Left Front (-) Green/Black
Right Front (+) Green
Right Front (-) Yellow/Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Green
Left Rear (-) Blue
Right Rear (+) Blue/Black
Right Rear (-) Blue/Orange
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | 1999 Mazda 626
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
Installing the Alpine IDA-X200
So it is powering up? On your actual deck will be a picture of the schematics of the wiring. With the system powered up, assuming you taped up the power wires, strip the front left wires coming from the deck and use them as your tester. You now know forsure they are for the front left so as you go through your cars audio wires you will find which wires are for which speakers around your car. Label them as you test them. Hope that helps.
Jan 14, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Car Audio & Video Logo
812 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
