RCA D52W19 52 in. Rear Projection Television
Problem for RCA D52W19 52 in. Rear Projection Television
TV turns on then off no picture
By ChrisFuentes on Mar 20, 2006
About 3 days ago I went to turn my TV on and the screen was blank. I turned it on and off several times and got it to finally come back on. The next day it did the same thing. I turned it on and off several times and finally got a picture but it was wavy. It went dark and came back on and then went dark for good. The green light on the power button went out and would not stay on. I can turn it on and the power button will get a green light for a few seconds and then turn off, there is not a picture at all. I have tried to trouble shoot. I have unplugged it overnight and I still get the same result. I would appreciate any help you could give me.
Same Problem
Apr 01, 2009
-   mine doesn't really turn off it just kinda flashes and looses sound. Sometimes it helps if I turn it off during commercials but it seems to be getting worse. It also seems to be doing it more at night. All my friends one of whom is an electrician said it was the power supply but I JUST HAD the POWERE SUPPLY FIXED about A WEEK AGO. It just gets so frusterating missing sentences. At first it seemed to do it at random but now it seems to do it more at the beginning or end of a commercial or, of course right when the show comes back on. I have had my RCA Proscan for about 12 years and it just started last week. If anyone has any suggestions please contact me at... SKDDUD@wowway.com THANK YOU.-   SKDDUD
Feb 02, 2009
-   sheesh im having the same problem. i even missed the super bowl :[ -   Guest
Oct 19, 2008
-   this is the 2nd tv that has done this to me. I have the tv plugged into a surge protector. I think the problem my be with in the cable wiring in the wall. I have a stero system plugged into the same surge and it has no problmes-   Guest
Nov 13, 2007
-   I have the same problem, took off the back cover and was dusty, but still no solution, probably think its a fuse, will try to unplug circuit board and see what happens , also will call or email co. for circuit board diagram. will get back to you-   russplasma
Best Solution
posted on May 27, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same thing happening to me
Solution #2
posted on Mar 20, 2006
Somewhat Helpful)
hendrix
Rank: Wiz
Rating: 77%, 745 votes
sounds like a power supply problem, it is possible that somehow its voultage got deadjusted and the extra current is shutting down the unit. May be pix tube, or crt drivers. Unplug the crt board to test, & measure for shorts on the crt board.
good luck
Was this helpful?
Yes
No
Solution #3
posted on Oct 01, 2006
Somewhat Helpful)
crycry
Rank: Apprentice
Rating: 81%, 4 votes
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA D52W19 52 in. Rear
Questions and Unsolved Problems for RCA D52W19 52 in. Rear
Do you recommend RCA D52W19 52 in. Rear Projection Television?
Answer
Answer
my 52 inch rear projection screen tv takes 4 or 5 tries before it will turn on and then the screen... (More)
Answer
wont turn on. green power light cycles 3 times. What's up?
Answer
when i try to turn on my tv i press the power button and it turns green for about 5 seconds then... (More)
Answer
i have a RCA D52W19 and I am seeing a green yellow and red color in center on the bottom of the... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , MD
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
