Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini - F 1-1 code
This code is appearing on the display. I understand it refers to a control board of some sort... Do I actually need to have someone come in and diagnose, or can I just order a part?
not sure if mine is the 6772 or 6769
  • 750 Answers
Hello amica,
Welcome to fixya,
You said, This code is appearing on the display. I understand it refers to a control board of some sort... Do I actually need to have someone come in and diagnose, or can I just order a part? not sure if mine is the 6772 or 6769
You can try to turn off the breaker for the range for FIVE MINUTES,.
And see if it resets the system. Otherwise you need a professianl dignoses, not to waste money on randomly changing parts!
Let me no the outcome.
I don't want you to waste money on parts!
Huuum
Please remember to leave a rating!
Posted on Oct 06, 2008
Maytag gemini model MER6770 AAW error codes F 1-2 and F 3-2
Sounds like a heat sensor and limit switch problem, but it could also be a control board failure which is also pretty common in Maytag appliances. Lately any Maytag i have issues with, dishwasher, range, clothes washer, etc, usually leads to a bad control board. But if the sensors are cheap enough i would try swapping them first and making sure connections are good on everything, thats the cheaper first step compared to replacing the control board.
May 04, 2017 | GE Profile J2B915 Dual Fuel (Electric and...
Tip
Maytag Gemini MGR6875ADS
if your hitting buttons and te display is not responding be sure your not in sabbath mode if so, refer to your owner's manual and it will tell you how to get out of it. and be careful whern you are cleanning that display. make sure you don't use any ammonia based cleaners. the display will soak up the ammonia base and cause shorts in the circuit, causing you to have to replace the display board.
on Oct 27, 2011 | Maytag Ovens
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
F1-1 reading on control board
F1:-1 may appear on your Gemini oven range for various reasons, but the meaning is always the same. The error means that the display relay control board thinks your temperature on your upper double oven range is running away and getting too hot. To fix the error F1-1, check the wire harness between your oven sensor and your control board to make sure the wires are secure and the connections are good. Pull the oven out and remove the back panel on the oven to check the wires connections. If the connections and wires check good, disconnect the wire connection to the oven sensor and check the resistance of the sensor. The resistance should be 1100 ohm at standard room temperature. If the sensor is not good you need to replace it, and if the sensor checks within range replace the display control board. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Maytag mah650aww diagnostic codes
The code is actually "2E".
The 2E refers to a problem with the motor control board. It has sensed a fatal error. The corrective actions needed in this case is the motor control board to be replaced. Here is the replacement control board.
Oct 18, 2012 | Maytag Neptune MAH5500B Front Load Washer
Power Interruption
power interuoption is a power cut / power went off it needs resetting your tech should be able to do this
Jan 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini mer6770aw
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
102 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
