Question about InFocus LP70+ Multimedia Projector
Fan problems The screen says "Fan problems. One or more of your fans have stopped." What do I do? I called InFocus support and was told that the vents may be dusty and to use a vacuum cleaner on low to **** away the dust. I did that, and the same message comes up when I plug up and turn on the projector. Any other suggestions besides sending it in for repair?
  • boomchuck Sep 26, 2008
    I get the same message. I did pull out the bulb and can see that one of the fans is not turning so this appears to be a real fan problem. Are these user replaceable?
  • 2,237 Answers
Find out which fan is not working and clear out the obstruction, if any. otherwise, you need to replace it. they are easy to replace once you find out which one.
Posted on Sep 03, 2009
I am getting a message on projector that fan stopped. what does that mean?
ur projectors lamp cooling fan have some problem. if the fan stopped the lamp will get over heated, that's why cooling fan is must. its a warning message if not it will create some problem to ur projector's lamp. u should use the projector only after solving the fan problem.
Dec 17, 2010 | InFocus Office Equipment & Supplies
Infocus LP240 fan shuts off
If you want you can check the voltage at the power conector on de main board. but the problem are the fans, replace the fans, and check the routing cable, its very important.
Jun 25, 2010 | InFocus LP 240 Multimedia Projector
InFocus IN2102EP. After about a hour the it starts to flicker between a white screen with "NO INPUT" message and the image. It stops for awhile and then stars again. It is running from Computer #1 input....
It MAY be a thermal problem.
Make sure there is no obstruction on ANY side within at least 6 inches.
Sometimes they put these in cabinets and that is a no-no as it reduces air circulation/
Check that the fan and all the vents are free of dust and if it has a filter, the filter is clean.
Try putting an additional fan blowing on the unit to see if it runs longer.
Also check your cable connectors are properly seated and screw locks are set. As things warm up, the cable might be marginal if not seated.
May 19, 2010 | InFocus In2102 Projector
there are 2 fan assemblies in this model. a double fan for the lamp, and a single fan for the dmd chip. check for obstructions through the vents (pieces of plastic or paper will stop the fan). if nothing is in there, you could buy the parts from an infocus service center and replace them yourself or send it to them to fix. either way, try av solutions in ny. they're really good.
Dec 12, 2009 | InFocus LP70+ Multimedia Projector
Infocus x1a fan replacement
to remove the fan: remove the 8 screws from the bottom of the projector (4 silver, 4 inset and brass) and the 2 screws from the back. pull the back from the bottom, but use a small flat-head screwdriver to release the tabs seen through the topmost vent of the back. once off, unplug the speaker wires on the right and the cable harness on the left. pull the top off while pulling the front off from the bottom. remove the wire harnesses from the power supply board and the ground wire from the power input board. take the 4 screws off of the power input board and the 4 or 5 screws from the power supply board (and 1 center clip) and remove. take out the 4 or 5 screws from the metal shield and remove shield. now you can unplug the fan that need replacing and access the 2 screws holding the fan in. remove fan and replace with a like fan. since the fan speed is not monitored, if you can find one that's the same size, power, and plug size, use it. otherwise, contact an infocus service center and ask them for infocus part # 526-0192-00. reverse instructions to put it back together. but you must remove the front from the top case, put the top on first, plug the speaker and left harness in, then put the back and front on. wasn't that fun?
Jun 02, 2009 | InFocus X1A DLP Slide Projector
Fan not going round properly in Infocus projector.
you have to remove the top: 8 screws on the bottom, 2 or 3 on the back, undo the clips in the top vent on the rear (using a flathead screwdriver), remove the rear, unplug the wires, lift off the top and front (from the front). there are 2 fans, a 60mm and an 80mm. both are available from an infocus authorized service center.
Mar 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
SP4805 Fan Issue
the fans in these models do not have a speed sensor wire to let the main board know to turn off the lamp to not risk overheating. so if the fan goes, the lamp remains on. however, if the lamp exploded, check the vents for dust. there is a temp sensor that will shut down the projector if it gets too hot. if the vents are clogged, blow the dust out of the projector with canned air. the dust keeps in the heat that the projector is trying to expell. easiest way to repair the fan w/o buying a part: splice the fan wires together. they can share voltage. if the 80mm fan does not work at all after that, replace the fan (pn: 526-0192-xx).
Jul 31, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus projector won't turn on
From the infocus_lp650 manual
Table 2:
Red LED Behavior Explanation
One (1) blink The lamp won't strike after five (5)
attempts. Check the lamp and lamp door
installations for loose connections.
Two (2) blinks The lamp counter hours have exceeded
lamp life hours. Replace the lamp and
reset the lamp hours counter.
Optional Accessories Part Number
Three (3) blinks The projector has shut down the lamp.
Replace the lamp. Contact Technical Support
for repair if replacing the lamp does
not solve the problem..
Four (4) blinks The fan has failed. Replace the lamp (the
lamp module contains a fan). Contact
Technical Support for repair if replacing
the fan does not solve the problem.
Five (5) blinks The projector is overheating. Check for a
blocked air vent. Contact Technical Support
for repair if clearing the air vents
Jun 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
4805 infocus projector
it is the colorwheel bearings going slowly due to excessive dust and heat. remove the lamp and push in the switch actuator on the lamp door frame. turn the projector on and see the colorwheel spin in the lamp housing window. does the noise happen when the wheel spins and stops when the wheel stops? let the switch actuator go. does the noise stop? it's the colorwheel (pn: 525-0146-00). you can get it through an infocus service center. try av solutions in ny.
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
Error "Fan Stopped"
yes. it needs the third wire to sense the fan speed. without it, the projector assumes that the fan is not running.
Aug 21, 2007 | InFocus LP640 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
168 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
