Question about Panasonic DVD-S31S DVD Player
My DVD player wont read a disc
I was watching a movie and my DVD player just turned off. Now it will turn off and on, But it will not read a disc. Ive tried several DVDS and ive tried unhooking everything and hooking it back up. Nothing seems to work.
  • Dumafach May 21, 2008
    I have an Apex DVD player. It will load and play mp3 disc but will not load a DVD and states on all disc that it is a bad disc. 2 laser cleaning disc worked but home theater setup disc will not load.
  • Anonymous Mar 20, 2014
    I can't seem to find a paper clip hole either
  • 30 Answers
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Posted on Mar 27, 2006
I have a go video vcr/dvd player. The vcr is working fine, but when I insert a dvd it shows that it is loading, it makes a clicking noise for a minute or two, and then stops. It displays on the tv, "unknown disc". Is it broken, in need of cleaning? Can you help me?
Posted on Jan 03, 2010
SOURCE:
Vcr hrxvc1u JVC how do i turn off subtitles on the vhs
VHS tapes u can't turn off Captioning as(subtitles to u) because the technology was not there yet.Captioning put on to help the hearing impair and the deaf to able to watch the movie too.Only DVD movies Discs and Blu Ray movies Discs give u this option on the main menu of the movies.
Jun 12, 2011 | JVC HR-XVC1U DVD Player/VCR
Is it possible to change the region code to region 3 so we can watch movies from Thailand? No need to switch back as I have another DVD on region 1. Charlie (cleggett1937@aol.com)
You can make this player REGION FREE so all discs operate on it.
Power up, no disk in. Status says READ then INSERT DISC.
Press MENU (status reads invalid key icon)
Press 1 (status reads invalid key icon)
Press 9 Menu is displayed.
Press ENTER on the region, digit turns to "-"
Press 0
Press ENTER again
Press EJECT to clear the special menu.
If you reset (unplug) the player for any reason - this will need to be re-entered.
Thanks for using FixYa!!
Mar 18, 2010 | Cyberhome CH-DVD 300 DVD Player
Dear Sir The dvd cannot read the disc
One of the problems with many DVD players is as they get older the spindle motor is unable to overcome the inertia of the spindle + the disc.
If this is the case the read head will try to hunt for the start of the DVD if it is not spinning then it wont be able to find the DVD. If you can access the DVD by taking the cover off you can give the DVD a chance to spin by giving it a little push if the player can find the DVD then you can watch the movie.
If this is the case you will need a new spindle motor fitting to your player.
Jan 06, 2010 | Polaroid PDM-0742 Portable DVD Player
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Dvd player wont read the movie i burned to watch-need firmware?
Did you finalise the disc. If not try that. These older units were made before there were a lot of "homade" DVD's and were never designed to play them. Sorry. Hope this is of some help.
Apr 07, 2009 | Sansui VRDVD4000 DVD Player/VCR
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Panasonic DVD-S31S DVD Player Logo
1,022 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
