Question about Yamaha RX-397 Receiver
YAMAHA RX-397 Unit won't power up below 255 volts
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    How do you arrange 255 volt for unit? as electric supply is some where 100, 110, 220 in world.
  • 10,594 Answers
I'm still waiting your reply.
Posted on Sep 10, 2008
Have a Yamaha RX-397 switched it on started smoking, switched it off straight away.
open u r RX-397 and see the main supply board inside it whare is u r main power cord is connected their is a capecitor of 200 to 400 volt it is burend so it smoking change it and enjoy
Feb 02, 2013 | Yamaha RX-397 Natural Sound AM/FM Stereo...
Rx-397 smoke came out
change it's main capacitor in main supply board inside RX-397 it is burnt so it smoks
Feb 02, 2013 | Yamaha RX-397 Receiver
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Trying to hookup XM radio to RX-397; no sound. Which inputs should I be using?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-397-Receivers-manual/id/320ag614/t/2/
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Of course, if your XM device has standard RCA outputs, use RCA cables without adapters.
May 27, 2011 | Yamaha RX-397 Receiver
I have a yamaha rx-v2092. The unit turns on for
it could be the problem with t108 transformer or with the power on relay circuit eg. zener diode
Jan 12, 2010 | Yamaha RX-V2092
My yamaha rx-550u receiver won`t power up, no lcd display,nothing?
open it up and check the fuses and the power supply should be +or - 45 volts and the low voltage regulator +or -15 vdc
Sep 15, 2009 | Audio Players & Recorders
Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
Jun 14, 2009 | Yamaha RX-770
YAMAHA RX-V630 WON'T POWER ON NO CLICKS
If the unit is like the Rx-570 , the display bulbs have quit.
Theyre 14 volt lamps about 0.1 wide x 0.250 long (white wire leads)
Located in the plastic shroud behind the display
Mar 23, 2009 | Audio Players & Recorders
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-397 Receiver Logo
333 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
