Question about Freezers
GE Profile side by side refrigerator-freezer PSC23SGNABS
My refrigerator-freezer was installed in 4/03. Both sides maintain perfect temperature. However, snow forms in the opening from the ice cube container to the in-door ice cube/water dispenser. I have tried emptying the ice cube container and cleaning the opening, but it just happens again. The temperature is set at zero; the door is not opened frequently. No odd noises either.
    Novelist:
  • 166 Answers
Hi sckk,
ngafm at your service,
Your indoor ice and water keeps getting iced up.
There is an air leak somewhere between the ice and water dispenser on the door and the freezer!
there are many places that this may be. But usually the spring loaded door where the ice drops out to the door ice machine!
It takes a good tech sometimes a couple visits changing a couple of parts till he gets it.
There is no sure fire way to diagnose which part is the culprit thats leaking air.You need an experienced tech that eyeballs it and knows what parts to choose first to be replaced.
The air leak almost microscopic to the eye.
Sometimes you take ice from the door and the crack only closes full some time after wards. Then the tech comes the next day and sees nothing. Or it is intermittent problem!
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
please give me a goo rating before you sign off.
Thank you.
Posted on Sep 10, 2008
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
What temperature should my GE profile fridge be set at so that my food does not freeze
depends on what type control you have . what is it set on now 6 then turn down to 3 or 4 .
Feb 27, 2015 | GE Profile Spacemaker Stainless Steel...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Water accmulation in the bottom of the refrigerator
Your drain line is probably plugged and causing the overflow during defrosting of the evaporator. It needs to be purged at the least or even cleaned thoroughly by removing the rear panel in the freezer to gain access.
Jun 11, 2014 | GE Profile : PSB42YSXSS 42" Built-in Side...
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
On the freezer side their keeps being water frozen in bottom
The drain to it is stopped up or the heat strip that melts the ice has gone bad. When working right, the water should drain out. The water goes into a pan under the freezer and evaporates.
Jan 27, 2013 | GE Profile Panel Ready 24.6 Cu Ft White...
GE Profile Arctica not making ice
Check to see if the fuse for the icemaker is blown. Check to see if the linkages are moving. Check the activation motor is getting power.
Jan 20, 2013 | GE Profile Arctica Customstyle...
Freezers Logo
253 people viewed this question
Top Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
