Question about Panasonic Lumix DMC-LC43 Digital Camera
System error turn camera on green light comes on as per normal functions ok to that point then lens retracts like it is switching off green light comes on and flashes with system error.if you hold the camera to your ear when all this is going on you can hear noise from within the camera before it starts to retract and green light starts to flash with system error on screen.this happens on all functions.you can still look at pictures already taken this funtion works ok.just can,t take photos any ideas please.
  • deobarr Feb 08, 2009
    My LC43 want take pictures. It just says "System Error"
    Champion:
  • 277 Answers
Hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Posted on Mar 21, 2006
SOURCE:
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
Error message 5e02: 5f08
Error 5e02: 5f08 means lens error.
Try resetting the camera, by removing the batteries, and by holding down Ok/function button while you turn the camera on.
If the lens do not extract, try helping them out by gently slapping the back of the camera while you turn it on. If they do not retract, try helping the lens back in while turning off the camera.
If that does not help, then the camera need repair service.
Jul 31, 2009 | Olympus SP-700 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Jan 01, 2008 | Pentax Optio S Digital Camera
Panasonic Lumix DMC-LC43 Digital Camera Logo
386 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
