Question about Harley Davidson Road Tech HA90 MP3 Player
Trans noise my transmission whines sounds like a siren i read that harley knows they have an issue with this but refuses to fix it
  • 91 Answers
Hey you didnt say the year when you say it whines the noise is from gear engagement lash (gap) you probaly have 10-50 or 20-50 oil in it to get it quiet put GL70-GL90 (gear lube 90 is easer to find and works great they harley used to use it in older bikes now they try to use the same oil 20-50 in everything engine, trans ,primary, hope this helps
Posted on Jan 01, 2009
Just changed trans oil in 97 flfts harley trans whining now
Did you use a synthetic trans oil as this is the required oil it must be a 20/50 and did you put 3.5 quarts in which is what the manual says which in fact you only need 3 quarts 3.5 is over filling and cause a wine in the gear box
Sep 04, 2014 | Motorcycles
Driving over 40mph hearing almost like a siren aka whining noise coming from the passenger side only happens when im driving more then 20min the siren tends to increase louder when driving faster when i...
Because the whine is still happening at high speed when your in neutral and low rpms it should not be engine or tranny related. I would start looking at wheel related issues. Hubs probably.
Nov 15, 2013 | Cars & Trucks
Transmission fluid pump
Transmission Pump Valve --most likely
To resolve all or any issues, you would have
to pull the unit & go thru it ,make the modifications
to the pump & valve body.
All transmissions come new from the factory with
known problems & there are known fixes for all of
them, with kits from Sonnax & Trans-Go
Use Google & You Tube Video to learn about
those issues,there is lots to read on the net.
Aug 22, 2013 | Ford E-150 Cars & Trucks
Whining noise coming from transmission
Sounds like nothing to do with the engine unless it increases with RPM out of gear. Can't be the fly wheel as what possible issue would make a piece of metal whine. Probably the tensioner pulley on the new belt.
Oct 15, 2017 | 1995 Honda Accord
2006 tacoma whining noise
I never suggest flushing a trans
Just remove the pan & clean
If you want most of the fluid out,
drive it a week or so then drain again.
I suspect the noise is the trans pump,
but don't know exactly how any dirt sediment
flushed into it would cause a noise
Jan 22, 2013 | 2006 Toyota Tacoma
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
1998 dodge ram whine noise..PLEASE HELP
how does the trans fluid look?at proper level?it sounds like the front pump in trans is starving for fluid..filter may be plugged..does it shift ok?any fault codes?i would check these things and probably drop trans pan to see if any debris/dirt/metal in pan indicating an internal problem..i hope this helps
Aug 15, 2009 | 1998 Dodge Ram 1500 4WD
98 fatboy engine noise.
Harley's do run hot, anywhere from 220 to 240 normally, and a little hotter this time of year. I suggest running a straight weight oil, and a little heavier weight in the summer. I use Valvoline VR-1 30 weight most of the year, and 50 or 60 weight in the hot summer, and I use Lucas 20w50 primary/trans for the primary and tranny. I don't bother with the extremely high prices of the HD oils. For the whining noise, you need to determine which side of the engine it's coming from. Whining will almost always be in the bottom end. There's nothing in the top end that should whine, and if there is whining from the top, it's usually an air leak around the carb. Start by checking the fluid levels in the tranny, and primary. These are the two most common areas to pick up a whining noise. If it's coming from the left, it's going to be in the primary, and usually this is caused by low fluid levels. From the right, it's going to be either the tranny, low fluid, or the oil pump. The oil pump is a gear type system. If you're running a light weight oil, say a 10w40 or HD 20w50, when the engine heats up and the oil thins, it can cause the oil pump gears to whine a bit, especially in the summer heat. So, check the fluid levels, if they check good, then change the oil, since the summer is coming to an end, go with a straight 30 weight. This should clear up the whining noise. If it doesn't, get back to me with the exact location the noise is coming from, and we'll go to the next level of diagnosing the whine, but I believe that this will cure it.
Aug 22, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
180 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
