Question about Magic Chef CER3740 Electric Kitchen Range
Oven does not heat up
My magic chef oven will not heat up to correct temp
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Posted on Nov 18, 2008
    Sergeant:
  • 234 Answers
Their may be any voltage problem can be occur in your home or otherwise oven heat producing transforming may not works correctly! if the fan runs heat not coming mean transformer only not working properly!
Posted on Sep 09, 2008
  • ra ja
    ra ja Sep 09, 2008
    nothing
3 Suggested Answers
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
Oven not heating
If your oven is gas, like it says up top, then your ignitor is bad...
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Magic Chef CER3740 Electric Kitchen Range Logo
703 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
