Question about GE DVL223EBWW Electric Dryer
How to replace the Belt
How does the Top or front panels come off?
  • 958 Answers
There are clips in the front side. pry slowly the top cover and what ever is holding it, use a screwdriver to push it a little bit to release the clip.
the top cover can now be lifted towards the back.
tnx 4 using fixya,
drcool
Posted on Sep 09, 2008
How to get inside and replace belt on washer model fws445rbs4 serial xc72602766
To replace that belt,use a flat blade screwdriver and place it between the top edge of front panel and top at the corners and pop up the top,raise the top,inside of the front panel at the top inside corners will be screws that hold the panel to the cabinet,remove those screws and push down and pull off front panel. To replace belt lay on the floor and grab old belt and rotate it off of the transmission pulley and pull it out,place new belt around motor and idler pulley and rotate it around the trans. pulley in a counterclockwise direction
Gene
Aug 10, 2011 | Frigidaire Washing Machines
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
How do I remove the top of a Frigidaire dryer - model GLEQ642AS2
I will include the instructions for replacing the belt, it will include the top removal and also a link that you can click on the see the belt routing.
http://www.applianceaid.com/images/belt-config.JPG
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 01, 2011 | Frigidaire Dryers
I am trying to replace the dryer belt. I cannot for the life of me seem to figure out how to get the top OR front panel off. Thanks for the help.
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Dryers
Are there 4 support rollers? Instructions on how to replace them. Thanks - Doug
Now you can replace your drum rollers at this time
Installing the belt
facing down.
Please RATE me
Dec 22, 2010 | Kenmore 800 7983 Dryer
I need to replace the broken belt on my dryer. Its a Frigidaire Dryer Model GLGR341AS4 The model of the belt is : WCI-134163400 AB I was able to remove the cover that exposes the motor and diagnosing the...
Unplug the dryer. Using a one inch paint scraper you can locate the two spring loaded clips holding the top in place. They are located about one inch in from the top corner of the cabnet between the cabnet and the top. Depress the clips one at a time lifting on the corner of the top,tilt the top back and rest it on the wall.Inside the dryer cabnet looking down you will see two screws, one on each side holding the front panel to the cabnet. Remove the screws and tilt the front panel forward. Mark and remove the wires going to the lid switch. Remove the front panel. Remove and discard the old belt. Slide the new belt over the drum with the grooves on the belt facing the drum. Reassembe the front panel of the dryer and replace the wires onto the door switch. Replace the two screws on the front panel. Reach into the rear access panel and grasp the belt. Pinch the belt and feed it under the pully of the belt tentioner. Pull the belt tentioner towards the motor pulley and slide the pinched part of the belt over the motor pulley.
Replace the inspection panel on the rear of the dryer.
Lower the top and press down to lock it into place and your done.
Jan 21, 2010 | Dryers
How do I get the back off my dryer to replace the belt Model #MDE9806AYW
no no no no need to take the back off, you just need to pop the top off, you should have clips on the left and right from the front inbetween the front panel and top, once you pop top up, on the left and right there are 5/16 th bolts that hold front to panel, take out 2 bolts and install belt around idler pulley and drum
Aug 24, 2009 | Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Jun 27, 2008 | Dryers
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
GE DVL223EBWW Electric Dryer Logo
131 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
