Question about Fargo DTC550 Thermal Card Printer
Shoving printer problems
Displaying card hopper malfunction
  • Anonymous Oct 02, 2008
    message displays card hopper jam -ie, the card hopper is unable to move to the proper position
    Genius:
  • 2,785 Answers
Plz replace the card
Posted on Sep 11, 2008
Error code 24:08
Hi There,
The most common reason for General Error 24:08;
Hand Feed Mode is ON. (only time this error is shown)
The printer expects the card to be fed from the manual card feed slot at the front of the printer.
If the card is 'manually' fed from the rear of the printer (with the rear card hopper removed), then this error message will be displayed.
Hope this helps,
Kind Regards,
MC.
May 06, 2014 | Magicard Office Equipment & Supplies
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
I have a pitney bowes copier model C350 giving me an error code C0072. What is this?
Sub Hopper Toner motor mechanism malfunction.Remove rear cover,pull out toner cartridge,Remove sub hopper unit fixed under main hopper toner assembly and change the sub hopper motor or the agitator levers gears.
Aug 11, 2012 | Office Equipment & Supplies
Card hopper lift erorr
card hopper lift problem the printer is tell me not ready i dont understand it speaches but i can tell you, please can you send the solution for me...... my email address: godfrey_cole111@yahoo.com
Dec 17, 2009 | Fargo DTC550 Thermal Card Printer
Cant slide the card hopper in the back of my magicard rio 2
Hi There,
Just go to the following web site;
http://www.magicardonline.net
Enter your printer's serial number in the QuickSearch box.
At the bottom of the search results you fill find a useful video tutorial called 'Loading cards'.
The trick is the hopper has to be offered up to the rear of the printer at a 45 degree angle, then as bottom of the hopper engages, tilt if forward and it will drop down into position.
Like you say, I am assuming that you have the correct hopper, but you will see the correct hopper on the video!
I hope this helps.
Regards,
MC
Feb 26, 2009 | Magicard Rio ID 2 Card Printer
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Resolving a Card not fed error (Cards will not feed off the Hopper)
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Card hopper jamming
Could be that your cleaning unit is not installed or is old. Or, it could be too few cards in the card hopper. You could apply a little weight to the cards in the hopper to see if that helps. And/or try changing out the cleaning cartridge.
Oct 04, 2008 | Fargo DTC520 Thermal Label Printer
Feeders rolling backwards
It sounds like the encoder settings are incorrect. See if the settings on the printer LCD panel match up with the options the printer physically has. On the display panel, press Menu> Setup Printer> Encoder settings> to see if it says "none" or "yes" for each of the options as you scroll down. When the printer has any one of the encoders physically installed, the mechanical direction of the drive train is reversed. The display settings correct for this by reversing the direction of the motor.
Mar 08, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
104 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
