Question about VeriFone OMNI 3200 (P092-101-10) Printer
No line error
When send out a settlement. I am getting a no line error. I have check connections and phone line. All appear to be in working order. I have reprogram the unit thru the service. Can the modem go bad. If so, is there a way to check it. If it is bad can it be repaired?
  • VeriFone Master
  • 19,396 Answers
Yes the modem can be the problem. Try first to disconnect everything from power and see if this help.
To test the modem you need to connect to the computer.
Posted on Sep 09, 2008
What is communication error 20 mean ?
The Comm. Error message may appear if the machine experienced a communication error while sending or receiving a message. This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line. In your case, it lost connection to the host / server. You just need to keep retrying or check the settings on the phone and confirm with the vendor if they have changed some settings on their end...such as PORT #, etc...
Sep 02, 2015 | Computers & Internet
We can't get the machine, OMNI 3740, to do a settlement says on ticket NO HOST FOUND, what do we need to do
No host means no phone line on connectivity. check wiring and make sure there is a dial tone if plugged into a phone line.
Feb 02, 2015 | Retail Supplies
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
What does comm error 20 01 mean on my brother 2820 mean? how do I fix it?
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Nov 03, 2010 | Brother IntelliFax-2820 Laser Fax
Sent a fax and report came back with result message"error 390" What does that mean? regards Lisa
Hi Lisa,
According to the HP manual, this error code is consistent with a communication error. in other words, the machine tried to send your fax, but could not get anywhere.
I would:
1. Turn off the printer, then turn it back on. send a test fax to another number, see if it works.
2. check where your phone line connects to the printer, and make sure the phone line is plugged in to the correct phone jack on the device. If it is, take it out, and put it back in. Test sending a fax again.
3. If this doesn't work, test your fax line. hook it up to a phone- see if you can hear a dial tone from it. If so, the line is active. If not, you may need to troubleshoot for a phone line problem, which your telephone provider can assist you with.
4. If the phone line is alright, but the printer still doesn't work- something could be internally wrong with the printer. Call HP for further support, and they will be able to assist you by getting it repaired.
Jul 16, 2010 | HP Photosmart Premium C309A All-In-One...
I can't send a fax on my lexmark 5400. It gets to
Do you have or does the receiving party have a DIGITAL phone line?
ALL fax machines are ANALOG devices.
Jun 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Cannot get the machine to send a fax
check phone line, does dial tone sound when normal phone is connected to phone jack in wall.
Check that you have connected phone wire to right socket behind printer. Some models have 2 diffrent ports for phone line ...
Upgrade firmware.
May 04, 2009 | Office Equipment & Supplies
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
VeriFone OMNI 3200 (P092-101-10) Printer Logo
249 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
