Question about Sharp 27H-S60 TV
Thin horizontal line
The whole picture is a thin horizontal line. I can tap the TV and the whole picture will come back but them goes away. after about 20 minutes the tv seems to be fine. Is it worth getting fixed? I am pretty handy can I fix it myself?
  • cracqal Nov 15, 2007
    the whole picture is a thin horizontal line. Started yesterday. I turned it off and unplugged the television, waited a few minutes, turned it back on and the entire picture was there as it should be. Came home today and it's doing it again. What's wrong?
  • NorrisE Jul 01, 2008
    same problem, can unplug tv for a few minutes turns back on then i get horizontal line after awhile
    Problem Solver:
  • 12 Answers
IT SOUNDS LIKE A VERT. COLLAPSE. IT MIGHT BAD CONNECTIONS IN THER VERT. DEFLECTION.
Posted on May 25, 2006
    Scholar:
  • 124 Answers
Defective components in vertical deflection and output circuit inclusive of vertical output device, coupling capacitors, and yoke connectors. Passive devices such as electrolytic capacitors, coils, and resistors to/from power supply circuits. If your tele is more than 10 years old dump it and get a newer product. $100 USD is a fair price to diagnose and attempt service, depending on age and configuration. Older products may not have replacment parts available at any repair cost. There may be a pot for adjusting the vertical size. If so, it may be dirty. If you can find it, try adjusting it which could clean it. BE CAREFUL -voltages are very high.
Posted on Mar 20, 2006
    Problem Solver:
  • 7 Answers
Thats almost definately bad solder connection. look at solder joints for cracks around teh lead. better yet, suck outold solder and put in new on any connections that have anything larger than a standard resistor lead. yoke plugs, tuner, etc
Posted on Jan 24, 2007
CHECK FOR BAD SOLDER JOINTS IN THE VERTICAL SECTION, CHECK JOINTS ON VERTICAL OUT IC FIRST
Posted on Jan 11, 2007
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
I have one very thin line, horizontal, in my picture, about 4 inches in from the left side. It goes away after the tv is on for some time.
could be a faulty connection when it happens move the plasma like rock it forward and back if it goes away then its a faulty connection if it doesnt then its the panel and not worth repairing
Apr 27, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
Televison & Video Logo
672 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
