I OWN AN EPSON CX6600 PRINTER RUNNING WITH A WINDOWS XP DESKTOP. MY PROBLEM IS WITH THE SCANNING 'SMART PANEL' SOFTWARE. I`VE LOADED ALL THE SOFTWARE FOR THE PRINTER FROM THE CD ROM THAT CAME WITH IT, WHICH IS FINE BUT WHEN THE SMART PANEL IS LAUNCHED IT`S INOPERABLE AS THERE ARE NO CONTROL BUTTONS ON IT.CAN YOU HELP? THANKS, TERRY.
  • 1,879 Answers
Need to check for an update - go first to support.epson.com
second place to look for updates is from the software manufacturer (yes it says EPSON Smart Panel but it is a bundled application)
www.newsoftinc.com
Posted on Sep 09, 2008
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Unable to use Memory Card with PC VISTA
The scanning software for your printer must be installed separately from the printer software on Vista systems. The following link will take you to the page to download the scanning software....just find your model number and select it:
http://www.epson.ca/cgi-bin/ceStore/support/supAdvice.jsp?BV_UseBVCookie=yes&noteoid=86150&type=highlights
May 03, 2009 | Office Equipment & Supplies
CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
Oct 19, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Scaner
As you have not mentioned your computer set up, I will have to assume you are using a PC and not a Mac and are running Windows XP.
Download Epson Scan (2.7u) from the Epson Web Site. This will enable you to control scanning via PC.
Jul 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
You cannot. Epson do not have a Vista driver (64 or 32) for the CX6600
If you have Vista 32 you can TRY and use the XP driver. Chances are however it will not work correctly.
Nov 15, 2007 | Epson Stylus CX6600 All-In-One InkJet...
81 people viewed this question
jasbo
jasbo
