Question about Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor
Dell Flat Panel repair
There are very small vertical lines in my display. All menus are clear. Just the display.
    Champion:
  • 277 Answers
Unfortunatly, chances are this is a hardware problem, but anyways, i would still recommend you reinstall drivers, or change them. various problems get fixed just by doing this simple action, so you can never know, it may save you lots of pain. in case this doesnt solve anything (which is most likely to happen), this can be a case of either bad cable, or bad graphic card. first, attach a new cable from screen to computer, and clean the outputs first. if it doesnt help, there is a chance display cheap is fried. btw, this vertical lines thing seems to be a common problem in several dell models. the solution i gave you are very general, so there's a good chance problem accurs from a bad product and there's nothing you can do about it but to call del and do some yelling. good luck.
Posted on Mar 20, 2006
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
How do i fix or repair 6 black vertical lines on the right side of screen?
Vertical lines can occur due to a loose contact of LVDS cable, to display panel and T'Con board. Re-seat it once and check.
Jul 11, 2013 | AOC Envision L32W461 32 in. LCD HDTV
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My Dell P2310H monitor has a vertical Blue line and a white horizontal line displaying on the monitor.
This occurs when you have lines of pixels go out or your video card has gone bad on your computer. You should hook it up to another computer to confirm which is causing the issue and repair/replace the problem device.
Apr 01, 2011 | Dell Professional P2310H 23inch Widescreen...
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor Logo
75 people viewed this question
Clive
Clive
Alun Cox
