ETW350 is programmable timer that offers 3 different timer
functions: Program, countdown and random.
Timer has 20 different settings.
UPM site is not available recently, but UPM timers are still being sold.
Operation manual is not very clear how to program ON and OFF times.
http://waterheatertimer.org/pdf/UPM-etw350.pdfThat being said, usually with programmable timers, you program ON time. And then program OFF time.
I do not own this timer so I can't test ETW350 like I've tested other timers.
I think the way this timer works, is program1 is ON.
And program2 is OFF.
Again, manual is not CLEAR about ON and OFF times.
Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
Here's how to set program1.
Press arrow buttons until 1 shows in display. This is program1.
Press Set button.
Select day for program1 ON using arrow keys
Press Set button.
Select hour for program1 ON using arrow keys.
Press Set button.
Select minute for program1 ON using arrow keys.
Press Set button.
Use arrow keys until 2 appears on display. This is program2.
I believe program2 is for OFF times.
Set program2 using same steps above.
Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
Make a schedule of program times before starting to avoid conflicts.
Try steps above and test fire that timer, and then add a comment.
