Question about JVC AV-32750 32" TV
Audio noise on cold start
When I first turn on the TV (JVC AV-32750), there is a terrible noise coming from the speakers for about 20-30 seconds before it starts to subside. Once warmed up, there is no noise. I can even turn the TV off and then back on without problem. It sounds like electrical interference, but I don?t think that is the problem since it has worked for years in the same location. I have the satellite receiver audio hooked up the audio receiver for sound so I have the speakers turned off and the volume turned down to zero. Thanks in advance.
    Champion:
  • 277 Answers
Hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Posted on Mar 21, 2006
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
May 13, 2011 | JVC AV-32750 32" TV
How much does the jvc standard tv model no. av-32750 weigh?
About 50 lbs,used to help friend tv shop fix alot of these standard tv.Carry them all the times.
Jan 13, 2011 | JVC AV-32750 32" TV
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
Green shadow
it is due to degaussing circuit. it has developed due to changing the side or turning tv or any thing is lying near tv which has got magnetic effect. solution 1 put of tv for 15 minutes 2 do not change direction while watching tv . 3 remove magnetic thing like speaker if is near tv. still if you donot get the result call tech.to degauss it with degaussing coil. it is 2 minutes job. good luck.
Sep 24, 2007 | JVC AV-32750 32" TV
Televison & Video Logo
98 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
