Question about Sony KP-53HS20 TV
Red block in the middle
There is a red block in the middle of my television. It makes the TV look like a reverse widescreen (dark in the middle light on the top and bottom) but the picture is still visible throughout the whole TV.
    Champion:
  • 277 Answers
Hi You have dry joints. Whack it hard on the side next time it starts going nuts and see if it comes back. That's always a good diagnostic tool for the pros. If it does, you have in intermittent connection that will deteriorate over time. If not, you could just have a bad convergence amp good luck
Posted on Mar 21, 2006
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
We have only had our television a year, and the colour is starting to change on its own to a dark red tone, and the 4x6 screen has been burned into the screen, making vey annoying to watch anything...
U have an image screen burn in.This is not fixable.This have happen,because u left the same image or setting on same setting day in day out,tv on all the times.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Big red circle in the middle of the picture
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2010 | Hitachi 51F59 51" HDTV Projection...
Phillips 55 Inch Widescreen HD TV, convergence repair, the red is off. The picture is not good. Can I fix this problem my self, and around how much will it be?
I'm assuming you mean the red light or lamp? provided you know the make and model of the TV, you can no doubt find a replacement bulb for it online.
Do a search or contact the manufacturer to see what they can do, but you should be able to do it yourself.
Oct 19, 2009 | Hitachi 53UWX10B 53" Rear Projection...
My tv is dark on the sides and light in the middle
Hi
ok you have defective RGB at the CRT board! the suspect is the variable resistor in green section and red section!
Thanks!
Dec 26, 2008 | Samsung TX-R2735 27" TV
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
2 Problems with my Mitsubishi 65" widescreen projection tv
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND
May 31, 2007 | Mitsubishi WS-65807 65" Rear Projection...
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Sony KP-53HS20 TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
