Question about Dometic Rooftop RV Air Conditioner
Dometic Blizzard 1300 roof top unit blowing fuses
When I turn on the unit it trips the main rcd switch in the caravan and the site we're connected to. Does anyone have any ideas on what I could try looking for. Also - does anyone have the manual for this model? Thanks.
    An expert who has answered 500 questions.
  • 540 Answers
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Posted on Sep 09, 2008
I have a Dometic 640315 that was installed by rv manufacter on breaker 15 amps. When i try to used it the breaker goes off.
I believe it is supposed to have a 15. Remember, breakers are installed TO PROTECT THE WIRE, NOT THE EQUIPMENT. If a breaker is tripping you just don't put a bigger breaker. The wire must be the correct size for the breaker. Take it to the manufacture.
Jul 08, 2017 | Dometic Heating & Cooling
How do i repair my dometic air con unit on caravan
When you say safety switch do you mean fuse or breaker? If your breaker is popping(110 volt) then if probably is your compressor overloading the system.i would do as advised before and remove shroud(cover on roof) and clean coils or fins with some otc coil cleaner. Ive been in the buisness eight years and only one time have i change a compressor. Most people get a new ac. Sorry for the bad news
Dec 26, 2014 | Dometic Rooftop RV Air Conditioner
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Oil leak on caravan roof top dometic unit
the only place for oil to come from is if you have lost refrigerant sometime when compressor goes bad and burns out you lose terminal seals and oil blows out.
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Dometic Rooftop RV Air Conditioner Logo
780 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
