Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacement light bulb for GE spacemaker microwave
My GE spacemaker microwave jem25gg001 (1998) has a burned out light. I need a bulb and directions on how to replace it
  • 6 more comments
  • maryjocarlso Sep 09, 2008
    I went to Repairclinic.com and found a bulb and schematic that (hopefully) will work. The exact model doesn't show up anywhere on any repair site. I do not think any appliance should become a boat anchor just because it's older than a Hollywood marriage.
  • maryjocarlso Sep 16, 2008
    I double checked the model number and it's the under counter GE jem25gy001 (not gg) but I will take it from the cabinet and try to replace the bulb I ordered online.
  • Anonymous Feb 12, 2009
    hard to find this bulb anywhere!!
  • Anonymous Feb 13, 2009
    What type of bulb Base and how do I remove? Thank you
  • Anonymous Mar 22, 2014
    GE model PEB159DMBB
  • Anonymous Mar 24, 2014
    how can i replace the heating element for a GE 1998 microwave double oven?
  • Anonymous Mar 30, 2014
    how to replace a bulb in a ge microwave oven JES1142SP1SS
    A standard microwave light 40w doesn't fit.
  • GE Master
  • 9,098 Answers
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
  • boris anisi Sep 05, 2013
    i want to know how does the bulb come out
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where can i order a replacement light bulb for the ge spacemaker microwave
is this inside or under microwave most lights can get at hardware stores
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
hold down the clear/off button for 3 seconds and it will unlock..
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,467 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
