Question about Bush 5693D 24" TV
Wont turn on
When you hit the remote to turn on all you get is red light flashing and a clicking sound in side tv the red light should turn green thankyou melv
  • 18 more comments
  • milltown Nov 16, 2007
    Akai turns on to green and after the Akai screen comes on the set immediately turns off and stays red. Numerous attempts over a week or more to turn the set on results in the same problem. Unable to get any picture whatsoever regardless of mode. Has anyone else experienced this problem and can anyone help? Thanks.
    Dan
  • Anonymous Nov 17, 2007
    Nope. Sony FD Trinitron WEGA TV just blinks red light and won't turn on. The manual is absolutely no help. As it states in the Troubleshooting section: Problem - "TV won't turn on and the timer LED is flashing." Solution - "Press power button on remote control or on the TV front panel." Well...if this worked then there wouldn't be a problem. So, now what? I was actually able to turn it on once and tried to reset the unit following the instructions. All that did is turn off the TV and went right back to the initial problem. Odd. Any suggestions out there. Thanks
  • chuck63 Nov 22, 2007
    tv does not turn on, red light flashed 3 times after you turn on
    have tried the reset procedures but nothing
  • sour Dec 02, 2007
    I called a repair company who came out and replaced a chip on the main circuit board. The chip controls the high voltage. According to the repair company, it's a bad design that will fail again. Unfortunately, new flat screens being offered don't have any better solutions. Built in
    obsolescence is becoming too comon in todays products. I guess, its business. If it doesn't break, you'll probably not purchase new ones.
  • Anonymous Dec 15, 2007
    turn power on...and nothing
  • Anonymous Jan 22, 2008
    Same thing. TV refuses to turn on and there is a constant clicking sound when plugged. I tried to plug it elsewhere, but the problem remains.
  • Anonymous Feb 10, 2008
    tv will not turn , beeping inside
  • sdmrt29 Feb 11, 2008
    When turning on the TV all I get is a flashing red light lasting about 10 seconds before I hear a click, another 15 seconds of red light flashing and then a click to shut everything off. It appears I'm not the only one with this problem. Someone else has had good luck with a circuit board replacement. I'll inquire at a couple of repair shops and determine if this is a solution to this problem.
  • sbaker68us Feb 29, 2008
    We are having the same problem, any idea on the circuit board what the cost was?
    Thanks,
    Shirley
  • Anonymous Mar 06, 2008
    Have exact same problem and Sony Hellas want to charge 340 Euros to be fixed.
  • MC HAZ May 16, 2008
    i have got a panasonic tv and the problem im having is that the red and green light keeps on flashing and the television is not turning on.
    can i kindly have a solution from one of the technicians of what i can i do and can i get rid of the problem.
    it will be very grateful of you.
  • Anonymous May 20, 2008
    When you hit the remote to turn on the tv I get a red light flashing, a clicking sound in side tv, and then the tv turns off. There is no picture at all while this is happening. Does anyone know what the problem could be?
  • doas698 May 21, 2008
    when you hit the remote to turn on all
    thankyou
    matt
    I have got a philips 30pw8859/30pw8869/30pw8879
  • mainerd16 Jun 15, 2008
    I have a lcd flat panel tv and when I turn it on my red light flashes and I here a click and it stays off
  • Anonymous Jul 06, 2008
    same as the bove descriptions
  • skyqueen13 Jul 19, 2008
    When I press the power button on the remote, the tv does nothing. I don't even get a sound...could this be the fuse? The remote does show a red light but tv has no lights at all....
  • Anonymous Aug 01, 2008
    no power
    No picture only blinking red power light on front of TV. Remote does nothing and the power button on the front of the TV does nothing. Is this TV a piece of junk. This is the 2nd Toshiba TV we have had problems with. Never again. Costs more to fix that they are worth. Model 32A32!!!
  • sleyeman Aug 03, 2008
    I have a Curtis Mathis CM36020s and all of a sudden it will not turn on! All that happens is the little light by the power button blinks on and off and the tv makes a clicking sound. I've tried unplugging it and waiting a while. That worked a couple of times but now it will not
  • Anonymous Jan 20, 2009
    Sony flat screen wega. Red light flashes five freekin times but wont come on. This is a 38" screen that costs me alot of money 3 yrs ago. Piece of ****. Throwing it in the dumpster tomorrow!
I took mine to a shop. They had to unsolder a bad chip on the main board. After they replaced it with a new chip, everything worded perfectly. They told me they do quite a lot of these. Everything else works great. This set has years of life left.
Posted on Dec 02, 2007
    President:
  • 3,130 Answers
The clicking sound inside the TV set is an indication that the power supply is working and that there is a short most likely in the sweep power supply or the horizontal output is shorted due to a bad connection on L1401, or the flyback is bad. This is not a job for the novice or a user unless you have Experience, troubleshooting solid state printed circuit boards. Call in a pro or take the set into a shop if you do not have any experience, as there is no user replaceable parts inside this set. Good Luck
Posted on Apr 11, 2007
The standby light flashing red is probably flashing a code, as sony uses this self diagnostic setup...for instance, my tv is flashing 5 quick flashes, pauses a second or so and repeats the 5 flashes...which should mean a problem with the AKB circuit (now if I could just find out what to replace). To see the diagnostic screen, Press the following buttons: Display, Channel 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred.
Posted on Mar 20, 2007
My mother's Zenith TV is having the same problem. It has turned back on twice now and I suggested she leave it turned on all the time. My father was an engineer and that's what he did with his TV and automobile tube radios--just never turn them off. It's a lot cheaper than buying a new TV.
Posted on Sep 07, 2008
Try soldering the main capacitor like a microwave has 2
Posted on Jun 03, 2008
  • 21 Answers
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Posted on Feb 08, 2008
I have a Mitsubishi CS-32307, when you hit the on/off switch the green light comes on and the screen acts as if it is warming up but does not come on. I took it for repair they said it was the on off switch not the tube. They had it for six months claiming that the part was on back order from the company. They also stated that they had tried a few used parts but that they didn't seem to make a difference. I am a single mom of 3 and I am in school (clinical studies), I need to make this TV last for just one more year. Any subjections?
Posted on Jan 02, 2008
Remove ur powercord and put it back and see if its turn on and you connot use ur remote let me know to my email micro_el@yahoo.ca, i can fix it for you,
Posted on Aug 24, 2007
Hoizontal high power over votage switch
WoW! I have the exact problem with my Aconda ACO9383S ! It just started today! The red light stays on, while the green light intermittantly clicks on and off... I've tried unplugging the TV fvor an hour, holding the on/off button in, yadi, yadi, yada.... HELP!
Posted on Nov 13, 2007
    Scholar:
  • 124 Answers
Is it possible to turn tv on manually? if it is, problem is with remote control. if it isn't, i would bet its a problem with power supply. Get out your DMM and measure the voltages in the power supply. if it is too high, tv will not turn on.
Posted on Mar 20, 2006
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
Sep 06, 2011 | Arris DCT700 DTV Receiver
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Bush 5693D 24" TV Logo
2,576 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
