Question about Dryers
Kenmore Electric Dryer, HE4, Model #110.85876401
Kenmore Electric Dryer, HE4, had a power surge, and only the drum light works. Replaced thermal fuse, front control panel, dryer cord, and still won't work. Outlet works fine. HELP!!!
the dr
  • 447 Answers
SOURCE: Kenmore HE4 Electric Dryer runs as soon as you plug it in, doesn't heat and display isn't lit
Make sure that the cord is installed correctly make sure that the white wire is in the middle of the red and black wires. Other than that it sounds like a Main computer issue.
Posted on Jan 16, 2008
  • 210 Answers
SOURCE: panel control
Check to see it he belt is good, there is a kill switch on the belt which will stop the operation. Could be a broken belt or bad switch. Spin the drum if it is too easy then it is the belt.
Sgt 48
Posted on Jun 06, 2008
SOURCE: Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
I have the same indications. It power up intermittently with the check lint LED lit. The manual said it will (lintLED) turn off when the start button is press but only gives me a beep when I press start. Lint LED only turn off when I open door. The dryer will function normally. I disassembled lint assemby and clean it thoroughly, including moisture sensor. I run a diagnostics, all LED lit with 88 displayed on panel. The second 8 flash with a continous beep. I check the power cord and removed panel but have not done a continuity check. The dryer is working now.
Posted on Aug 18, 2008
VOTIT
  • 2071 Answers
SOURCE: Kenmore electric dryer HE4 dead,
Just click below the site links;
http://repair2000.com/dryer.html
Hope it may helps you;
Regards,
VOTIT
Posted on Sep 23, 2008
Maytag317
  • 1136 Answers
SOURCE: Broken door handle
Hi, there should be two screws holding the handle. I looked up my suppliers and this would need to be ordered. The cost is between 21 and 29 dollars, depending on color.
Part#8559750 Graphite color or P#8559751 Black
If I can assist you further, please let me know. I can order the part.
Thanks
Vic
Posted on May 15, 2009
I have Kenmore electric dryer. When I start dryer the drum spins for couple of cycles and stops. I found out that all rollers, and pully are free to rotate but motor is too hard to turn. So I replaced
if it shuts down and then comes back on, there may be a loose wire in the connector, when the connections are weak, wires overheat, and overload protection kicks in. just an idea for you.
Dec 16, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE4 dryer and it is not heating up. I changed the coil and cleaned out the lint. Is there a reset button?
If it isn't heating up but running otherwise, you probably blew the thermal fuse. The thermal fuse is often blown by the high limit thermostat going bad, and thus may need to be replaced also.
Mar 10, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 - no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer works, no heat
have you checked the power coming into the dryer?is the drum spinning?let me know-mike,
Sep 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model no. 110.85087400 won't start
hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Fuse
one fuse is on the heater housing the other is on the blower housing if you have not removed it the wiring diagram is inside the console
Apr 10, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
121 people viewed this question
Top Dryers Experts
