Question about Cisco 7912G IP Phone
"Edit" softkey is not working, Can't enter NTP or TFTP on Cisco 7912 phone
I can make and take calls on my phone and when I used to do " **# " I could enter the 1234 default password to unlock the Padlock Icon and get into "Network Settings" and "SIP Configuration" on the IP phone. I never got around to resetting to a unique password. Now when I do " **# " it does not ask for a password and also when trying to enter a TFTP Server, NTP Server or other info, I have no option to do so as the "Edit" softkey is not there.
I also went into the phone via HTTP and while I could enter the info there, the phone would not save it. I tried erased the config to start over and still would not let me enter the 1234 password or create a unique password.
Has anyone ever encountered this problem before? How was it fixed? Thanks in advance for any replies.
  • 48 Answers
I would try logging into your CCME and deleting that phone from the user list. That way, it will have to contact your server and redownload all the necessary files. If that doesn't work, I would try using the factory reset code which would completely reset it. Both of these require that your server is up and running properly.
Posted on May 18, 2009
DND, Headset, Mute and Speaker lights on. Why does it appear to be dead?
Your phone is probably broken. I have the LG IP8830 witch is a similar model and I'm using it with the SIP firmware. I have never seen my phones come up with a blank screen. You can try re-loading the firmware if you have it. You will also need a TFTP server setup. You can run TFTPD32 on a Windows PC as your tftp server. The following are the steps for re-installing the firmware on the IP8830.
Phone lock-up maybe caused by an error in transport during the
software upgrade. To correct this problem:
1. Disconnect power from the IP Phone.
2. Press and hold the [Up] and 2 button while reapplying
power.
3. Release the buttons when the Message LED extinguishes.
4. When the BootC screen appears, enter the digits 1, 2, 3
and 4.
5. Follow the prompts to configure IP parameters for the IP
Phone.
6. At the "Server Addr?" prompt, enter the TFTP server
address where the IP Phone can find the BootC firmware.
If already correct, press the [Next] button.
7. At the "Do you want to apply default?" prompt select the
[Yes] softkey to use default or [No] softkey to use
previously assigned parameters.
The IP Phone will reboot and return to normal operation.
Hope this helps
May 26, 2015 | LG Ericsson LIP-8012D 12 Button IP Phone
W580i gprs setting vodafone postpade
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
Feb 19, 2013 | AT&T Sony Ericsson W580i Cell Phone -...
Vodafone live postpade gprs setting w580i
8. On the 'Account Name' screen, enter 'giffgaff WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'giffgaff.com' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'giffgaff' and press 'OK' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'giffgaff WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
20. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
Change Homepage:
29. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'giffgaff ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://giffgaff.com/mobile' and press 'OK' (left softkey).
36. Highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
The GPRS WAP settings are now complete.
Sony Ericsson W580i MMS
You'll need to complete all steps for this to work.
Please also ensure the GPRS WAP settings have been entered prior to entering the MMS settings.
2. Highlight 'Messaging' and press 'Select' (left softkey).
3. Scroll to 'Settings' and press 'Select' (left softkey).
4. Highlight 'Picture message' and press 'Select' (left softkey).
5. Highlight 'Validity period' and press 'Edit' (left softkey), highlight 'Network maximum' and 'Select' (left softkey).
6. Highlight 'Read report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
7. Highlight 'Delivery report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
8. Highlight 'Signature' and press 'Edit', highlight 'No signature' and 'Select' (left softkey).
9. Highlight 'Creation mode' and press 'Edit' (left softkey), Highlight 'Unlimited' and 'Select' (left softkey).
10. Highlight 'Picture scaling' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
11. Highlight 'Auto download' and press 'Edit' (left softkey), highlight 'Ask in roaming' and 'Select' (left softkey).
12. Highlight 'Accept messages' and press 'Edit' (left softkey), if not already ticked highlight 'Advertisements' and press the left hand soft key 'Mark'. If already ticked leave. Ignore 'Anonymous' Press 'Save' (right softkey).
13. Highlight 'MMS profile' and press 'Edit' (left softkey).
14. Highlight 'New profile' and press 'Add' (left softkey).
15. Highlight 'MMS profile name:' and press 'Edit' (left softkey), enter 'giffgaff MMS', select 'OK' (left softkey).
16. Highlight 'Message server' and press 'Edit' (left softkey), enter http://mmsc.mediamessaging.co.uk:8002' and press 'OK' (left softkey).
17. Highlight 'Internet profile' and press 'Edit' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
18. Select 'Save' (right softkey).
19. Highlight 'giffgaff MMS' and select (left softkey).
20. Press 'back arrow' (key to left of navi key) 5 times, to return to standby screen.
The MMS settings are now complete.
Feb 19, 2013 | Sony Ericsson w580i Cellular Phone
Hi,i wanna use cisco ip phone 7940 as sip ip phone.when i power up the phone ,it can get ip from network,but finally,it shows "TFTP timeout"in display led.All the buttons can not be used.What...
the DHCP server should be providing the address of the TFTP Server as DHCP Option 150. The most likely problems are:
Option 150 not defined, or not the correct IP address of the TFTP Server.
Or possibly your TFTP Server is not functioning properly.
If you have not Option 150 defined, the phone will use the default gateway as the TFTP server address.
Cheers, Simmo99.
Dec 29, 2010 | Cisco 7940 IP Phone
How do i switch voicemail off g600
To find where to enter the Voicemail number your phone, please follow the instructions below;
1. Select the menu (press the Navi button).
2. Highlight 'Settings' and 'Select' (left softkey).
3. Highlight 'Message settings' and 'Select' (left softkey).
4. Highlight 'Voice mail number' and 'OK' (left softkey).
5. Highlight 'Voice server number' and 'OK' (left softkey).
6. Press 'Options' (left softkey) highlight 'Edit' and 'Select' (left softkey).
7. Highlight 'Edit Number' and enter '901'.
8. Press 'Options' (left softkey) highlight 'Save' and 'Select' (left softkey).
Jan 21, 2010 | Samsung SGH-G600 Cellular Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
How to Install LIP 7016D - IP Phone,I dont know which IP addresses should I give.
For startimg IP Phone you should have a Router details e.g. TFTP, Gateway (Router IP), if DHCP is configured on your router that time that time pls don't assign mannualy IP on IP phone.
Complete these steps:
1.On the Cisco IP Phone, press the Settings button.
2.Press **#
3.When the window displays Settings Unlocked, click the More softkey.
4.You now see the Erase softkey, which can be used in order to erase the configuration on the Cisco IP Phone.
I hope that this has been very helpful for you
Dec 23, 2009 | Computers & Internet
CISCO 7912 Ip Phone,Red lights are continuously on.
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Cisco 7912 sip phone
Can you please make sure that you can ping the device - you might have a routing problem
Feb 28, 2008 | Cisco 7912G IP Phone
Cisco 7912G IP Phone Logo
365 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
