Question about Asko T701 Electric Dryer
T700 Dryer Won't heat
We have a 1999 T700 dryer (similar to T701). The other day the dryer didn't shut off, the clothes came out very hot and smelled a bit burned. Now the heating element will not come on at all. The drum turns so it's not the reset, the fuse appears OK, but I'll replace it anyway. I changed the lower panel and fan cover so it can be easily removed for cleaning (which we do frequently). I removed and cleaned the entire internal ducting system as well as the ductwork to the outside. Checked all the connections from the top. The nearest ASKO repair is 100 miles away. Any ideas other than buy a Maytag ?? Thanks
  • 550 Answers
Not turning off, is caused by a small stepper motor attached to the back of the timer, that actually moves the timer (if a mechanical knob, my memory for obscure (sorry) models isnt perfect) they fail and are replaceable, separately to the timer, or the timer can be replaced with a rebuilt one, at approx the same cost as buying a stepper motor,
No heat is caused by the failure of a thermal cutout(thermal fuse overtemp cutout or any of a dozen other names) a small device like this T700 Dryer Won't heat - 5850e1d.jpg or this 4947033.jpg screwed on the ducting between the fan housing and the exhaust, with wires to the terminals.
when you stopped the unit while it was very hot, heat built up enough that the thermal cutout melted. test with ohmmeter or bulb and battery, no conduct -replace
Notes
There are only a few cutouts common to most dryer models the local parts guy will have one to fit, even if marked with a different brand name,
generic compatible timer available at local parts guy
saving a 100mile drive
Posted on Sep 09, 2008
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
May 15, 2010 | Asko T701 Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
Asko T700 overheats and shuts off
replace the timer or temp sensor
Aug 27, 2009 | Asko T721 Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Asko T701 Electric Dryer Logo
166 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
