Question about Philips GoGear SA178 MP3 Player
FORMAT PLAYER WHENEVER I START MY PLAYER IT SHOWS PLAYER PROBLEM -LINE 1 CONNECT PLAYER TO PC -LINE 2 FORMAT PLAYER -LINE 3 BUT WHEN I CONNECT IT TO MY PC IT DOES NOT SHOW If i try to add music to my mp3 they don't play and they don't display in the play list and when i try to format it, it doesn't want to do so it simply give me an error code in my pc
Format nasıl atabilirim
Posted on Nov 29, 2008
  • 8,596 Answers
Use the Philips Device Manager to perform a Repair
Posted on Sep 13, 2008
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
Tip
Sansa Mp3 player frozen? How to reset and format if needed.
To reset your Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch.3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
You will lose all your music - sorry. Also try: 1. From the Main Menu, in the player -> select Settings -> Format.2. Select Yes.
You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the player to the PC in MTP (See next step to change to MTP mode) .
1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that...
Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
on Jan 24, 2010 | Audio Players & Recorders
How do you reset a Mp3 player with 512 mb but it doesnt have a reset button?
To reset your Sansa Mp3 player. 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes.
You can also format using Media Player if you have unfrozen your player. 1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) .
Sep 17, 2010 | Audio Players & Recorders
Will not turn on
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Apr 16, 2010 | SanDisk Sansa Fuze MP3 Player
The device freezes after the welcome screen, updater won't work.
It may have the latest firmware already on it. To reset your Sansa Mp3 player2_bing.gif.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
You can also format using Media Player2_bing.gif if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) .
Click on the Sync tab.(be sure your player shows in the pull down menu2_bing.gif)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Apr 03, 2010 | SanDisk Sansa e260 MP3 Player
My sansa clip is frozen how do i reset
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using media player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu, Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My Mp3 player is frozen on a file it says it's chargeing when its not
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa m250 MP3 Player
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
FORMAT PLAYER
may be u dont have windows XP service pack 2 installd... install it thn try to connect./
Aug 27, 2008 | Philips GoGear SA178 MP3 Player
Why after formatting it shows only 440 MB?
1. You can format your mp3 player as usual drive format in winxp
2.whenever you connect your Mp3 player, a new drive is allocated
3.in the my computer wizard .click the mp3 player drive- Right click-Format-defualt allocation size-quick format(recommended?
Nov 27, 2007 | Philips GoGear SA178 MP3 Player
Philips GoGear SA178 MP3 Player Logo
53 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
