Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air Oven Model # SVE47600B Error Code F7
I am getting a F7 error code and beeping on my Jenn Air Oven. When this happens the only buttons that work are the cancel button and clock button.
then i have to program the clock in order to use any other buttons. when i first plug in my oven i get a flashing # 56 then the oven starts to beep and then i see the F7. i press the cancel button and then the clock button, then program the clock in order to use any other buttons. this will only last for a few mins. until it starts beeping again. How do i attempt to free a stuck button and if that is not the problem should i start with the clock assembly first or the touchpad?
  • Jenn air Sep 12, 2008
    I replaced the touch pad part # 71002033 average cost $157.49 and my oven works like new.
    Thank you to this website i was able to fix the problem without calling in a service tec.
  • aj
    aj Dec 08, 2008
    The F7 error code appears and beeps incessantly. If I press a combo of buttons including the cancel/off it stops for a period of time. If I just press the cancel/off, it stops for a few minutes or less. None of the other buttons work. The stovetop works fine. I have unplugged it, I have hit the breaker.
    It began after i used the broiler. how can i get it to stop and resume it's normal usage? Please help. I can't even afford a $157 part right now. Is there a way to reset the memory? I am not convinced the darn thing really has a problem.
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Posted on Oct 11, 2008
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
F-7 error code on jennaire oven
I think that is a problem with the control assembly.
Try first unplugging power cord for ten minutes , and see if this clears the error message.
Nov 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Why won't it operate?
Hi Pam, Is this not covered in the user manual? Additionally search online by "error code f7 f1" and see what hits you get.
Jul 10, 2015 | Jenn-Air JJW9630C Expressions Collection...
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Oven inop error code f7
This is your ERC ( electronic range control) that has gone out on this unit. We are factory authorized Jenn-Air service and parts supplies and we LOVE the Jenn-Air brands. Our house is full of Jenn-Air appliances, also.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we can next day air the correct part to you first thing Monday so you can start cooking for the holidays!
We answer our phones from 7 AM until 9 PM CST from Monday through Saturday and look forward to helping you to get cooking again.
Thanks, Ella
Nov 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
1,601 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
