Question about Canon PowerShot A40 Digital Camera
Canon A40 Shutter Stuck The Camera works fine with all icons but it appears that the shutter is stuck open causing a black screen. Please advise how to solve this problem by myself. thanks and regards
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
  • 38 Answers
It is impossible for the Shutter to be stuck, as the A40 does not have a Shutter. Sounds like you have a bad image sensor. I would contact Canon about this as they acknowledge a defective sensor in some of their models. However, depending on how old the camera is and depending on if it is one of their recognized defects, you may have to purchase a new one. Wait, what do you mean by shutter? do you mean the little covers on the front that open to exspose the lens? the little curtin like things? Tap on the front this can sometimes snap them open. If you can see the glass in the front and its still black, make sure your "display" button is not set to the off mode. Sometimes it can power on and the display will be off because it was turned off before the last time you used it. If its still black it could be a bad connection inside, wich controls the camera section inside the unit. If you bang or bump the camera ont he side will the screen flicker or show purple lines? sometimes show an image?
Posted on Mar 22, 2006
Black screen icons show up on screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 09, 2011 | Canon PowerShot A610 Digital Camera
Our canon powershot s21s appears to be working except the screen and the veiwfinder are black. What does this mean?
A stuck shutter is another common failure mode for digital cameras, and especially so for the Canon S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Mar 22, 2011 | Canon PowerShot S2 IS Digital Camera
Canon S3 IS , the display is black, icons are fine. Both in the visor or in the 2'' display ????
Jan 10, 2011 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot S3 IS shutter problem. Shutter does not respond. Screen is black. No pictures are seen. It sounds like it it taking a picture, but doesn't. When looking into lens, it doesn't appear the...
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
May 14, 2010 | Canon PowerShot S2 IS Digital Camera
Everything appears to be working on my camera however i cant see anything on the viewfinder its always black. I can look at pictures ,take pictures with flash, but they are black, please can you advise
If your camera is an SX110 IS, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
However, if you made a typo, and your camera is really an SD110, the problem would then likely be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Feb 16, 2010 | Canon PowerShot SX110 IS Digital Camera
Although the camera takes pictures does not show on screen and photos are black
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
But if your camera is not on the above list, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jan 21, 2010 | Canon Cameras
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black lcd screen on Ixus 70 shows icons but will not take picture
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A40 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
