Question about Refrigerators
Fans stoped hi, i have kalvenator having model E381T its colling is very poor not making ice and also the fans r not working can you tell me what to do. thanks, khan
    Master:
  • 497 Answers
I guess there is frost lining up at the back of the fridge try a defrost and check if it wrks..
or
It could be a bad fan motor, bad contactor, bad run cap, a blown fuse(if you have them), burned wire, just to name a few thiings..check them too.
Thanks for using Fixya!
Posted on Sep 09, 2008
We have a e381t model refridgerator/freezer. there is a rattle/scraping noises coming from the fan in the freezer part. There is ice behind the protective sheet that separate the fan from the main area. Is...
If there is noise of the fan rubbing with the frost build up on the freezer then it is confirmed that the defrost timer is faulty. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 17, 2011 | Fisher and Paykel Refrigerators
Not making ice fast enough
frezzer must be about 5 deg for ice mker to work . some models have a fan to speed ice production .. .. ck thes things . and adjust freezer tempt . .. also clean the cond coils . if dirty cooling is poor .. mm hope this helped .. feed back pls ..
Jul 10, 2011 | Samsung RF265AA Bottom Freezer French Door...
The temp of the fridge has gone up to 18c,an has stoped cooling .what could be the problem .how do i repair it
forst off i need the model number,second tell me what's going on,is there ice or like a snow buildup on the back inside wall of the freezer?if so you have a defrost problem,if the freezer is on top is there ice leaking down into the fridge section,if so you could have a blocked drain,also open the freezer door,do you hear the fan blowing,if not you could have a bad defrost fan motor,send the model number and check some of the things i just asked about and i'll be glad to help you out
Oct 19, 2010 | Refrigerators
Has stoped makeing ice and none of the door controles work. model SH205298
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
2004 santa fe AC only blows cold for a minute or two, then continues to blow air, but no longer cold....tried refrigerant, but didn't solve the problem....Any ideas?
I would first make sure you didnt over fill the system, you may have to exvacuate the system and then recharge it, then watch to make sure the cooling fan is colling condensor, if fan is not working that may be the problem,next if fan is working i would check for power at clutch, this will tell you if the clutch is bad or if its loosing power to clutch,you should have gauge to watch the hi and low side preasure readings.
May 12, 2010 | 2004 Hyundai Santa Fe
FP E381T, lights won't stop flashing, fridge not cooling properly
There is another fan to draw air into fridge compartment- access via fridge: remove back panel (long plastic cover- just clips off). Remove control housing (again, just clips off- careful of wiring though). Fan is located up in this channel between fridge and freezer compartments. However, from what you are describing, I think you have a blockage in the freezer drain, causing a build up of ice in the freezer which blocks the air flow to fridge.  To check, remove rear panel of freezer (clips off- you need to press down two clips at top of panel, they can be tricky to get off!!). Disconnect fan motor wiring by unclipping plug connection, and remove sensor wire(white wire) so panel can be removed completely. Now have a look in the trough underneath the evaporator, and check for ice buil up- there should be no ice in this trough. If it is iced up, you need to defrost ice and then pour some water in the trough and see if it runs away. In the middle of the trough there is a small hole where the water should run down and away to collector tray at rear of fridge- if this hole is blocked, water won't run away, so builds up and freezes and blocks air flow to fridge. If hole is blocked, poke a wire down to unblock.
If in doubt, call in the experts- F+P fridges can be a bit fiddly getting apart, as everything clips together ( I worked for F+P for 10 years, and I still sometimes have problems getting panels off easily!!)
Good Luck!!
Mar 10, 2010 | Fisher Refrigerators
Commercial refrigeration motor over heating and low suction press
Add 404A to system. It is low on gas. But kep an eye on the TXV for ice buildup. Make sure unit is free of ice before you charge it. It is difficultr to charge a refer system when itis iced up. Rus
Dec 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Frigidaire refrigerator not working colling
Can you tell me a little more like sounds of fans or compressor sounds. Lights on inside. When you open freezer is fan running? I will give you a try on fixing this. Let me know also if the model number above your post is the model of your refrigerator. Let me know if I can help you, Thanks, Sea Breeze
Jun 18, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
