Hdd Thanks guru for your quick response it is there but i still cant access it
  • gurrier Sep 09, 2008
    it wont let me change it
    it says in properties beside location, location 0 (channel 0 target 0 lun 0)
  • 928 Answers
Does it display a drive letter? If not right click it then assign a drive letter.
If after you set a drive letter then it should be accessible.
if still after this the same problem exists then you must use a recovery program to recover the files on the drive as the drive most likely is corrupt and defectivce.
Posted on Sep 09, 2008
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
Tip
Removing Viruses and Malware
This is the best way I have found to cure a machine infected with Viruses or malware<br /><br /><span style="font-weight: bold;">If your computer has an internet connection and you can access http://www.malwarebytes.org</span><br /><br />--download the free edition of malware bytes antimalware install and update it to the latest definitions and run a quick scan this is the best software available for free to fix infected pcs once the scan has finished and the computer restarted your virus and malware woes are over<br /><br />i<span style="font-weight: bold;">f the virus or malware is blocking your internet and you are unable to access http://www.malwarebytes.org it becomes a little more complicated</span><br /><br />--you will need access to a machine that is not infected use this to download the latest version of malware bytes and place it on a usb stick<br /><br />--next download the manual update definitions from http://malwarebytes.gt500.org/ transfer these with the usb to the infected machine run the install and the updates then quick scan and your golden<br /><br /><span style="font-weight: bold;">if for some reason you cant access malwarebytes.org and you cant install software on the infected machine </span><br /><br />--this is the most difficult and not recommended if you don't know your way around a computer you will have to open up the computer<br /><br />-- once the computer is open remove the hard drive and install it as a secondary drive on a non infected machine<br /><br />--on the non infected machine install malwarebytes and update and run a quick scan it will scan the infected hdd as well and cure it take the now clean hdd out and install it in the original machine<br /><br />--boot up the original machine download malwarebytes on it and run another scan just to be sure<br /><br /><span style="font-weight: bold;">99% of viruses and malware can be removed from the above methods however sometimes and infection is so bad that the drive has to be wiped and the operating system reinstalled</span><br />
on May 13, 2011 | Computers & Internet
Toshiba SE-R0340 remote control for RD100kb HDD/DVD recorder: only some buttons work. I can use select, guide, on/off but not Top Menu, fwd/back, skip fwd/skip back etc just nor response to these at all...
open the r.control and clean the keypads with contacts cleaner from dirty, corrosion, oxide, replace batteries and clean contacts batteries from oxide too. try again.
God bless you
Sep 24, 2013 | Televison & Video
Dear Guru, im Peter thanks 4 ur quick response however my problem still remains with LED samsung 40''...i have no display just standby red light it connected with cable (satellite televion) and remote...
Hello Peter, my suggestion is unplug your cable satelite (STB) conection.
Turn on the TV and see if there are changes or is still standby.
If your TV like normal after unplug satelite tv (STB) connection, you should check you STB.
If still not working, try to unplug AC cord from power line. Wait until led display indicator off, that plug again. If it still not working, i think you should call samsung technician to check you tv.
thanks.
Mar 17, 2011 | Televison & Video
I forgot hdd password how to unlock
Toshiba highly recommends the customer to fully understand what HDD Password is and once registered please keep your "PASSWORD" in a safe place.Your HDD password is different from your BIOS Password. Your BIOS Password is stored in the computer, but your HDD Password is stored in the HDD unit itself. So even the HDD unit is removed from one computer and attached to another, the HDD password is required to access it.If you forget your HDD User Password, TOSHIBA will NOT be able to assist you, and your HDD will be rendered COMPLETELY and PERMANENTLY INOPERABLE. TOSHIBA will NOT be held responsible for any loss of data, any loss of use or access to your HDD, or for any other losses to you or any other person or organization resulting from the loss of access to your HDD. http://aps2.toshiba-tro.de/kb0/TSB6B01MC000CR01.htm
Dec 07, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
Hi, i juz bought a Fujitsu Lifebook P5010 with a
check the jumpers on the drive if not u have a motherboard problem. GOOD LUCK
Sep 21, 2009 | Computers & Internet
Maximum harddrive size for netvista pc
well i think you could get away with 120 gigs. if you go over that you should update your bios and run a utility like Big Drive Enable--
http://www.seagate.com/staticfiles/maxtor/en_us/downloads/big_drive_enabler.exe
there are others out there though.
Dec 25, 2008 | IBM NetVista PC Desktop
Thanks for your very quick response
Hei Frend, nice to know about that.
Cheers...
Apr 20, 2008 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
