Question about Protron PLTV-32 Television
Pltv-32c black horizontal curved line like sagging seal on top of screen
Has anyone seen this? What is it? Can I fix it? I took the tv back cover off but decided not to go further until I hear from someone more experienced with this tv. I'll never buy an off brand again even if the picture quality is best for the price.
My Protron 32' has a droopy dust seal at the top of the screen that is getting lower. I took it apart until I got to the screen assembly and decided to look for a professional answer.
Posted on Sep 10, 2008
Tv picture shift leaving one inch of white vertical stripe on left side. Any suggestions as to repairing?
there is not really a "fix" for that besides buying and installing a new lcd panel. you have bad pixels. unless someone took the tv apart before this happend. then its probably a plug not inserted in all the way for the lcd
Feb 18, 2016 | Samsung PN64F8500 64" Plasma 1080p 3D HDTV...
Xbox360 has sound but no picture
If you look up further on this thread i HAD the same problem. This is how i fixed it. I needed it to red ring so i could send it back in to get replaced since my 1 year warranty was up. But i fixed it instead. So here is how you do it. First i took off my hard drive on the 360. Then i plugged it to the TV not with HDTV (use the red, yellow and white make sure it is on TV not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i plugged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wrapped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 minutes depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room. if this don't help you now you have a red ringed 360 and you can send it in to get repaired since there is a 3 year warranty for red ringed 360's.
Good Luck!!
Thanks!!
Aug 14, 2010 | Microsoft Xbox 360 Console
I have a problem with my PS3 System. When I turn
You can try two things easily:
While the PS3 is off (solid red led) hold down the power button until you hear the SECOND beep, quickly release.
If that doesn't work try it again with the hard drive removed from the PS3.
If neither suggestion solves your issue you can try hooking the PS3 up with different cables ( a/v or hdmi) but I have NEVER seen cables go bad, but still Sony suggests you try.
More than likely the issue you are experiencing is related to the GPU on the motherboard.
There is a DIY approach to fixing it but I suggest sending into Sony for a solid repair.
You can contact SONY @ 1-800-345-SONY
Hope this info helps.
May 26, 2010 | Sony Playstation 3 (PS3) Console
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Air filter keep popping on screen and shut off after 1 minute.
I had the same problem with my Panasonic tv, just 3 days after a technician came out to fix "fuzzy spots" which were multi colored, but mostly green spots. I really thought that the technician was in some way responsible, but Panasonic insisted that there was no possible way he was. It was going to cost $240.00 for him to come out to clean the air filter, and both the technician and Panasonic insisted that I couldn't do it myself. I had decided to buy a new tv to cut my losses. My boyfriend talked me into trying to fix it, we are both sort of mechanically inclined, and it was going in the trash anyway.
We took the back and top off the tv. It took some looking, but we finally found the filter, just over the projector. We removed the cover, it has to be done from the back of the tv, it is black and held on by 4 small screws, be careful not to drop them into the tv, we dropped one, but it shook out. We vacuumed the filter really well, and vacuumed around everywhere. We put the tv back together, not expecting it to work, but thinking at least we tried. It works great. It has only been a few days, but it seems like the problem has been solved.
Good luck if you decide to try. I have decided not to put another penny into the tv.
Jan 07, 2009 | Panasonic PT-60LCX64 Television
Problems with Samsung LE40F86BD
switched off and doesnt power up
Dec 02, 2008 | Televison & Video
Mitsubishi television
Good Day;
If you have a "BOX" use the video inputs. This way it will by pass the broken connectors. Yellow, red & white. if not try: 1-800-553-7278 or FAX; 1-800-825-6655. Good Luck, big IRISH.
Sep 17, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Sound but no image on JVC AV-48WP74
I have one with the same problem. I get a popping sound from speakers and a black screen. Any ideas what to check?
Feb 15, 2008 | JVC AV-48WP74 48" Rear Projection...
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Protron PLTV-32 Television Logo
113 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
