First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Usually a saw that size will have it's own breaker built in, is this the one that is tripping? Or is it the one on the wall? Either way, a dull blade will make the saw work harder, and heat up faster, Mine trips off now and then, always from a dull blade. It has a built in breaker in the switch. Are you running it with a cord? Make sure it is heavy enough, a small cord will steal amperage from the circuit turning a 20 amp breaker into a 15. Hope this helps.
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
many models have a 'breaker' on them somewhere if the motor overheats, pulls too much current, etc. You may need to crawl under your saw, depending on the model, and reset it (typically a red button to press in). Otherwise, make sure the receptacle you have plugged it into is not tripped by plugging something into it that you know works.
