Question about Sony Televison & Video
ERROR CODE 3L 11 AC IS ON MY VCR MODEL SLV-760HF WON'T EJECT TAPE ON OPERATE AT ALL. PLEASE HELP
  • 15 Answers
SOURCE: vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
  • 883 Answers
SOURCE: Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Posted on Feb 05, 2008
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Posted on Mar 02, 2008
  • 3 Answers
SOURCE: VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Posted on Jan 02, 2009
Getting code 1L 22 AA on SLV-760 Sony I got from friend. Only plays 1 second than stops. No manual avail.
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-find.pl?mdl=SLV-760hf
Oct 27, 2010 | Sony SLV-760HF VHS VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Feb 29, 2008 | Televison & Video
Feb 04, 2008 | Televison & Video
Sony vcr model slv-m91hf
make sure the tape is not missing its tab which is on the left hand side of the tape at the back
Dec 09, 2007 | Sony SLV-M91HF VHS VCR
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Televison & Video Logo
300 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
