Question about Imperial IR-6-C Elite Gas Kitchen Range
Imperial oven door won't close properly
The door was taken off my Imperial oven and it has never closed right sonce it was put back on.
  • jabri4me2 May 09, 2009
    Where can I get oven door hinge replacement parts for my
    Imperial Range 6 burner, 24 inch grill and two ovens?
Oven door closes but does not fit snugly against the face of body of oven. have taken door out and put back in/on with no joy, owner of oven thinks it has been like this since new.
It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
Mar 12, 2015 | Ovens
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
Oven door has dropped & won't close properly
You may need new hinges or the door is possibly out of the hinge socket. Try removing door and putting it back in place. These instructions should be in your users manual.
Jun 17, 2011 | Ovens
I put in a new switch for the top oven but the convection fan is going on only in cool down mode not on oven mode. it should go on when oven turns on (button up) but goes on when button clicks down (cool...
Door needs to be closed in cook mode to work. You sure you put the switch in the right way up? Also you could have a dodgy door switch as the cook/cool switch and the door switch operate as a two-way circuit.
Nov 20, 2010 | Imperial ICV-2-H Turbo-Flow Electric...
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
Imperial IR-6-C Elite Gas Kitchen Range Logo
178 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
