Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Exterior side walls VERY hot
A 2 year old Frigidaire freezer, the side walls to the freezer are VERY hot to the touch, especially in the middle and above. ONe side wall is open to the air, the other is against a wall. The freezer seems to operate properly.
I have noticed this for about a week now. it may have been occurring for much longer.
This certainly is not normal, nor correct. Any suggestions on what the problem might be
    Novelist:
  • 166 Answers
Hi wjjlaw,
ngafm at your service,
Is the hot side th open side or against the wall or cabinet side?
Have you touched this side before in he two years you have this appliance? Or is it that you just noticed it?
And if you can keep your hand on that spot for a long time it is not so hot only warm? If it is not burning your had it is probably just the characteristic of that fridge!
Check if the freezer part is full to the top and packed full.
Freezers can not be so full that you cover the cold air vents usually found in th rear of the freezer.
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
Please give me a good rating before you sign off.
Thank you.
Posted on Sep 10, 2008
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Sides of upright freezer are very warm to the touch
Good Afternoon Chuck, thank you for your inquiry! From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the freezer. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Aug 21, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Appears to run fine. but everything thawed. black canister at bottom (with coper wires from it) is hot to the touch. approx 3 years old
Compressor is supposed to be hot... your problem may be that the unit is stuck on defrost cycle... The defrost timer should be behind the kick panel and have a dial type adjustment on it.... find it and try to turn it just a touch. It may come on but you will need to replace it if it does
Jul 20, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have 20 cubic foot frigidaire freezer 2 years old. both of the sides are warm to the touch.(approx 70-75 degrees) the door is cold. inside no problem. very cold question: is this beginning to fail and...
YOU HAVE TO REPLACE THE CAPACITOR ON THE COMPRESSOR.. THAT WILL TAKE CARE OF YOUR PROBLEM,, YOU CAN ORDER AT TVPARTSANDMANUALS. COM THEY HAVE PARTS FOR APPLIANCES.. THEY ALSO HAVE A UNIVERSAL ONE THAT IS EASY TO INSTALL COMES WITH INSTRUCTIONS.
Dec 14, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have an upright Frigidaire freezer. The outsides (left and right) are hot to the touch. Is it a problem?
No. Instead of exposed coils on the back side, many (most) freezers place the condenser coils near the outer wall of the freezer to disipate the waste heat removed from inside the freezer. It will not be as noticable when the freezer is not running, and is completely normal.
Jul 09, 2009 | Freezers
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
362 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
