Question about Apple Power Supply 344 Watt PowerMac G4 Quick Silver (p/n 661-2513) 344-Watt Power Supply
System32.ntfs is missing and corrupt - Apple Power Supply 344 Watt PowerMac G4 Quick Silver (p/n 661-2513) 344-Watt Power Supply
    Scholar:
  • 124 Answers
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Posted on Mar 21, 2006
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
I turn on my Eee pc and it says a file:system32\Drivers\Nfts.sys has corrupt or gone missing
I would take it to a local shop to get it fixed. If you have to ask, it is most likely beyond your skills.
This issue is known to be caused by one or more of the below causes.
  1. Other software or malware corrupts or deletes the ntfs.sys file.
  2. Overclocking / heat related issues.
  3. Corruption in the computer memory or memory in computer is bad.
  4. Other serious file corruption issue.
  5. Other hardware confliction or issue.
Aug 12, 2010 | Computers & Internet
Won't finish boot because bad or missing system32/drivers/ntfs.sys file
There's a few ways to fix this. Easiest way is to just reinstall your operating system. That will wipe out everything and i assume you have data that you don't want lost.
Here is an alternate route. That file is stored on the disk in the I386 folder. Below is a link with the directions.
http://support.microsoft.com/kb/822800
Be prepared, there is still a chance you could lose your data, but the above link gives you the best chance at fixing the problem.
Oct 26, 2009 | Microsoft Computers & Internet
I am having trouble running setup on my desktop
Aug 28, 2009 | Computers & Internet
It can run at booting time my computer not working
Yepp, you can repair it, yous boot up from you windows disk and you will coma to a spot when you will be asked to install or repaire you OS, select repair and windows will install that corrupt or missing file
Nic
Feb 10, 2009 | Microsoft Windows XP Professional
Hard drive backup
This seems to be a good article on ASR backup and how to eliminate your error message.
See Link
Dec 16, 2007 | Dell Latitude D600 Notebook
Crashing!!!!!!!
First go to recovery console. try this command after the command prompt. CD system32\drivers\ Enter Last line should be: C:\windows\system32\drivers> then... Expand the file from the CD. expand d:\i386\ntfs.in_ or expand d:\i386\ntfs.sy_ if this doesnt work try to run CHKDSK /R. if you get any error while running checkdisk repair you will need a hard drive replacement.
Oct 03, 2007 | Dell Memory Board PE6450 (1409D) Expansion...
Apple Power Supply 344 Watt PowerMac G4 Quick Silver (p/n 661-2513) 344-Watt Power Supply Logo
306 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
