Turn the laptop and you'll unscrew the screw just near the battery, the pull the optical drive then put in the new one & tighten the screw again
You may get a service manual to be able to do this. Try as i might i cannot find a free manual there are 3 options below where you can purchase the service manual
http://www.free-service-manuals.com/members_signup.html
http://www.mitac.manuals-in-pdf.com/mitac-c-114.html
http://www.manuals-in-pdf.com/8355-p-1150824.html
For clarification: you will change the dvdrom drive of your laptop, right?
Always start laptop dis assembly with removing the battery or you can
damage the system board if you accidentally touch it with a screwdriver
and shorten traces. Removing the keyboard strip is not very difficult,
use your fingers to release the plastic latches. If you want to replace
the keyboard, do not forget to unlock the connector on the system boar
before you pull the cable.
