Question about Zenith B25A74R 25" TV
Sound Problem When I turn on my television I immediately get a high pitched sound that does not go away. I have a piture but the high pitched squealing sound stays there. How can I resolve this problem.
    Scholar:
  • 124 Answers
This is a very common problem, caused by failure of IC MM201 (usually located on the plug-in board containing the IF can, which you should also repair as long as you're taking the board out; solder connections commonly fail on this board causing intermittent or total loss of tuner video). The high-pitch whistle's the most common symptom, but it can cause a number of things. Any time there's a sound problem such as low or distorted sound, whistles, static, etc, change the IC. It's available from MCM Electronics for about $15 There is a kit of surface-mount caps available which supposedly will repair these little buggers. It's not worth the time and effort, just put in a new one. BTW, replacing the part is not difficult, but does require soldering skills. If you're not comfortable with soldering, you could remove the entire circuit panel (I believe the M board) and take it to a shop. If you call around, you should be able to find a servicer to replace the part for a nominal fee.
Posted on Mar 21, 2006
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High-pitched chirp at same time every night
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Feb 16, 2014 | Refrigerators
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
My disher washer is making a high pitched sound when I turn it on.
is this a new unit or old one? the high pitched sound is the pump some models make this sound every time they start up. it will make the sound when you start it up but then goes away. try this before you start it run the hot water in the sink let it get hot turn off the faucet then turn on the dishwasher.
Feb 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
High pitch sound
If the sound goes away when you turn it off, its the colorwheel. If it keeps running for another 1-2 minutes (cooldown) then its a fan. Both are changeable by a technical person, the colorwheel being much more intensive disassembly. Let me know if you need help there.
Dec 16, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture no sound only the power light turn on and off
Hmm, sounds like a fuse has blown, and this is a problem that I recommend only those comfortable around high voltages try to fix......
Dec 22, 2007 | RCA F36650 36" TV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Zenith B25A74R 25" TV Logo
91 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
