Copying How do I make a color copy of a colored original.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the make and model of the copier you are working with?
  • 1,326 Answers
Besides using a full color copier to make the copy. Not really sure what you are asking??
Posted on Sep 10, 2008
How to thread a Juki MO 816 DD6 industrial serger, please.
Did you get a book with it? If not, buy or access one online.
Copy the threading diagram from the book:.
1. Blow diagram up to full page size on the copy machine.
2.Make as many copies as the # of threads you are going to use (3 threads=3 copies, 5 threads=5 copies etc.)
3.Buy as many colors of magic marker as the number of threads you are using. (Or borrow from your kids, the neighbors or use crayons)
4.On copy #1, using the original threading diagram, use one color of magic marker to follow the thread through its patch from the thread cone to the needle.
5.Do the same with each of the other copies: Copy #2=thread #2, Copy #3=thread #3, etc.
6.Now you should have a page for each thread as it comes off the cone.
7.Use a thread color that corresponds to the magic marker color on your page to make it clearer. After it is threaded properly, you can tie the color you plan to use and pull them through.
By using different color threads, and a good light, it is easier to see if you have missed a place or crossed a couple thread improperly.
If all else fails, try to find someone else who knows how to do it to thread it for you, then take a couple close up pictures of the inside of the machine with it threaded properly, take them to the photo shop and have a copy made to keep with your machine to refer to in the future. Good Luck! Sergers are their own nightmare to thread but once you get it down, you will be fine and love it. Juki is one of the easiest of the bunch. If you have a pair of tweezers and a couple threading wires, it sometimes helps!
Jun 25, 2016 | Juki Sewing Machines
Why does my HP OfficeJet L7780 print blank copy with the regular copy
This is normally caused by a driver issue. Check that your device driver is correct for this particular machine.
Oct 19, 2014 | HP Officejet Pro L7780 All-in-One -...
I wont you to help me as to how i can make a photocopy using my canon ir 3100cn machine. than you
have you ever operated a copier? it,s so simple place the originals face up on the DADF. SELECT the no. of copies. there will be option available on display for selecting whether you want B&W or color copies like b&w, auto color, full color etc. there will be copy ratio button for zoom(25%-400%). Now press start button.
For two sided copying press "two sided". There you will have mainly two options (i) 1>2 sided:- converts two single sided documents in to a two sided copy (ii)2>2 sided:- converts a 2 sided document into a 2 sided document. normally both will be done in book type for normal orientation.
Apr 11, 2011 | Canon iRC3100 Printer
How do i use my scanner?
If you want Photocopy by using scanner just put your original document on scanner and press copy option.
here is two copy black and color for black copy and color copy
If you want to scan from printer to PC. Install scanner software from your driver CD and use scan sofware.
Remember that you can use only page for scan. can not use book. because this is not flatbed scanner.
Thanks
Sk. Abdus Sabur
Nov 29, 2009 | HP Officejet 4315v All-In-One InkJet...
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Use Copy Option
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make a copy
1 Load your original on the glass.
2 Press Copy, if not already lit.
3 Press Start Black or Start Color.
Feb 14, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to get glowing effect in coreldraw
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Dec 19, 2008 | Computers & Internet
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
29 people viewed this question
jasbo
jasbo
