Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
F-05 on Ariston Margherita AIB 16
My wash stopped and I get F05 on the machine display.
Tried to put it on again everything ok but... It does not pump the water out and it does it makes some noise.
Help
I had the same problem. try emptying the little chamber at the bottome front of maching. there might be something in there. then have a look at the little grey fan thing. give it a push. if it springs back it is working if not it is broke. tip the machine on its side and undown the filter part. ordr this section online. it is easy to replace. i done it myself. Lu
Posted on Sep 26, 2008
My spin cycle on my ariston aib 16 is locked as OFF, how do i turn it on
You have given little information.
Check is not littered filter of the pump adown washer machine.
Needs information that works?
It Is Flooded and meets water? Works die out?
Works the pump?
Apr 16, 2014 | Indesit W 123 Front Load Washer
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Fault F 05
This error relates to an object or piece of clothing blocking the pump, Clear it by taking off the inlet hose and releasing the object then all should be ok again
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
2,182 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
