Question about Sony VAIO VGN-FJ270/B Notebook
Hard disc I have changed my lap top's hard disk from 60G to 160G but it still shows capacity as 60G. How can I fix that?
  • 405 Answers
The drive needs to be re-formatted and re-partitioned to allow for the new capacity.
Posted on Sep 09, 2008
Seagate's DiscWizard, Extended Capacity Manager didn't recognize a hard disc with MBR partition style larger than 2TB when trying to maximize the capacity of the 3TB Seagate ST32000641AS drive...
Seagate Extended Capacity Manager
Seagate Extended Capacity Manager lets your operating system support large size discs with MBR partition style, so then you are able to use the space beyond 2 TB: this free space will be recognized as a separate disc, and will be accessible by your operating systems and applications as if it was a regular physical hard disc.
Seagate Extended Capacity Manager wizard will display all hard discs larger than 2 TB (unallocated or with MBR partition style). You can see, which disc space is recognized and allocated by Windows - this space is called Native Capacity in the wizard.
The space beyond 2 TB is displayed as Extended Capacity Zone. You can enable Extended Capacity Discs, and once it is done, this space will be visible by the operating system and ready for disc management operations.
Click Allocate space to see the possible disc space allocation in the next step.
After clicking Apply changes now button, the Extended Capacity Discs will be emulated on your physical disc. In case your physical disc is larger than 4 TB and the host operating system does not support a GPT partition layout, there will be several Extended Capacity Discs.
Note these Extended Capacity Discs are not bootable, and most properties will be the same as a physical disc's.
After allocating the space, you may temporary switch off Extended Capacity Discs by clicking the corresponding option. This will make Extended Capacity Discs invisible for Windows Disc Management tools, though the disc space will remain allocated.
To disable Extended Capacity Discs, click Remove partitions from Extended Capacity Zone and then click Apply changes now button in the next step: these discs will be removed from your system, and as a result - the disc space beyond 2 TB will become inaccessible
Sep 15, 2011 | Seagate Technology Barracuda Xt...
I am trying to acess my external hard drive but my lap top will not see it
first format your drive, using disk management tool
my computer right click-->manage-->disk management (show your drive hear)
Aug 14, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Hello.. I need some help. I am using toshiba satellite a1O system unit..my laptop was fyn till nw..all of a sudden windows doesnt load..when i turn the power on, the toshiba logo is shown..then black...
Hello
First thing you do is to see what hard disc installed in your laptop. You can check that by checking it in your bios system. To check in your bios system first turn off your computer then press delete while your laptop is booting up. Then you will see if there is a hard disk detected in your lap top if there is a detected hard drive this means you have a problem in your windows installed in your lap top.
There is also a reason why those message appear if the first boot of your laptop is the CD/DVD ROM. Check you CD/DVD ROM if there a CD inside this may the first on to read while the laptop booting up. Remove the cd inside your CD/DVD ROM. Then restart your laptop. Check your hard disk connector it may have some loose contact thats why your laptop did not recognize the hard disc.
Hope this can help keep on touch with fixya. Hope to hear some testimonial from you. . .
Aug 12, 2011 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
My 160g freecom hard drive has stopped showing my files says its empty but i have 20g of space used how can i get them to show up again?
make sure your reading the files on the same type of system.. if it is formated in NTSF you can only read in in newer windows systems, if it is in FAT32 it needs to be read on a fat32 system
Sep 12, 2009 | Freecom (24358) 160 GB Network Hard Drive
GATEWAY LAPTOP WON'T RECONIZE WD1600BEVT(NEW) NO HARDDRIVE
Have you try to right click the hard drive and click explore. more likely this will openif you can see the icon. the other way to access the external internal hard drive click start, click control panel, click administrator tools, click computer management, on the left hand side click disk management. All hard drive will show or appear and you can format, rename and do partition, the hard drive that you having a problem to open. You may choose primary or not to format. I hope this will help you to solve the problem.
HH
Apr 07, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
Hp pavillion9000 notebook hard disk broken
yes, just insure that you have the correct hard drive.... ata or sata.
Jan 26, 2009 | HP Pavilion dv9000z Notebook
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Loss hard disc capacity
Did you happen to re-install XP before this happened? WinXP prior to SP1 can only "see" HD's up to 127G, so that might cause your problem...make sure SP1 or SP2 is installed, or try Partition Magic and see if that helps.
Feb 17, 2008 | Computers & Internet
Sony VAIO VGN-FJ270/B Notebook Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
