Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Arm trtainer, left and right
How do I install the arm retainers to a bissell pro tec carpet shampooer
    President:
  • 1,673 Answers
Belt side takes the larger one, it just slips in slots and has a screw to hold it. The smaller one, put it in the small space and line it up so the screw hole matches up, insatll the screw.
Posted on Sep 18, 2008
I NEED A MANUAL OR H ELP IN USING MY bissEL pRO hEAR2x, cAN YU HELP ME Professio;nalol style carpet shampooer?
User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guide and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jun 17, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I bought a Bisell Pro-heat carpet shampooer and had the belt break after one use. Tried to buy replacement belts only to discover that store out of stock. Question: Is there such a thing as a "generic" or...
No unfortunately not. Some brands of vacuums and steam cleaners have similar belts that can be used on several different models, however this Bissell carpet cleaner has a very unique belt, that is really unlike any other belt on the market today.
I'm sorry to hear that your local store was out of stock on these. We do however have these belts in stock ready to ship today if you haven't already found them. We do offer free shipping & no tax (except VA). Here's a link to the brush belt for your Bissell:
http://www.govacuum.com/bissell-proheat-steam-cleaner-replacement-belt-part-0150621.html
Please feel free to add a comment if you'd like help installing the belt, I'd be more then happy to walk you through this.
If you found this helpful, it would be greatly appreciated if you rated the repair helpful, or left feedback.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes not spinning on my Bissell carpet shampooer (pro heat turbo 2X)
Dog hair may cause this, clean this unit, take sissors and cut hair.
Feb 14, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Need to replace a broken brush belt on Bissell Pro Heat Model # 88910-W
easy, unscrew the bottom plate, keep in mind that most bissell shampooers have one belt longer than the other based on the left vs right side
hope this helps
Sep 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Carpet cleaner not working properly will not send out the water
his is a very common problem with Bissell Carpet Shampooers...
Fortunately it has a very simple solution.
The problem is caused by blocked water jets ! and if your machine is still under the two year guarantee,Bissell will collect and repair very quickly free of charge !
Good Luck !
Call them on
0844 888 66 44 - Option 1 (UK Only) (Monday - Friday, 9am - 4pm)
Sep 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Replace bel
There are 6 screws on the hood, remove them. Unscrew the cap which holds the red x in place and remove. Gently pull up on the top housing and it will come off. Remove the 4 screws which are on the pump and slide the pump out, install belt and reinstall
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Fit a pump to Bissell proheat 7920e
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
57 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
