Question about GE GSS20IEM Side by Side Refrigerator
Ge Artica Side by side Modell PSS25NGMA, replacement of part WR57X10026
I was on line recently & found out how to replace the water lines from the part to the water dispenser/ice maker but am now at a loss to install the new unit in the proper way back into the refrigerator.
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
GE Artica no water, no ice, Checked water supply to solenoid OK
did u check water line after solenoids. could be a vaccum or u could have bad solenoids, not opening to allow water to go into box, try ok.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
No water through door - PSS25MGMA WW - replaced water bracket and valve assembly - GE Profile Artica
Since you have already replaced the water inlet valve , at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is also a water dispensor heater kit , pt # WR49X10173 , which comes with installation instructions .
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Artica black water supply line cracked/broken
Go to sears.com, click on "Parts Direct", screen will pop up, enter model number, press enter, wait a few seconds, you will see diagram of your unit, locate part & part number, order from sears or any parts house that sell appliance parts.
Sep 23, 2009 | GE GSH25JFR Side by Side Refrigerator
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Reconnecting part wr57x10026 back into GE artica pss25ngma
i found a drawing diagram sir. i could send it to your e-mail...
tnx drcool
Sep 09, 2008 | Refrigerators
Refrigerator GE artica pss25ngma
hi, i just saw this post. do you still want to talk to me?.
drcool
Replacing water "distribution" module in Artica side by side refrigerator
You should be able to look at your new valve to see openings for water lines. There should be little rings around each opening. Press down on these on your old valve to release water lines. Some older valve have threaded openings that just screw off. If that's the case, your new valve probably doesn't have the threads. Just push the plastic nut up the line and insert water line in new valve firmly until you feel it snap into place. Your water source line from wall will probably still screw onto valve.
Aug 29, 2017 | Refrigerators
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE GSS20IEM Side by Side Refrigerator Logo
163 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
