Question about HP Officejet Pro L7590 All-in-One InkJet Printer
HP L7590 All-in-one
I can't seem to find a way to have this machine provide me with a receipt for a fax which is sent and received from this fax. Without that, I have no way to establish that that the fax was received.
  • Anonymous Sep 15, 2008
    I want a fax confirmation
  • 3 Answers
Use the lcd screen menu on the L7590. chose either basic or advanced setup. i forget which oine. it will ask if you want a receipt afer ech transmission. toggle the arrow button to yes. then press the "OK" button.
Posted on Oct 03, 2008
  • grb48 Nov 08, 2010
    That option is not available in the L7590 menus
Can receive faxes but can't send
It almost seems your HP machine is arbitrarily denying you access to long distance numbers. Try referring this issue directly to HP for an explanation.
Dec 20, 2013 | HP Officejet Pro L7590 All-in-One InkJet...
How do I print a fax confirmation AFTER I've sent a fax on the HP L7590?
The product can print confirmation reports automatically for each fax that is sent and received.
Printing fax confirmation reports
  • The default fax confirmation setting is Off . Use these instructions to enable printed fax confirmations.
  • Press Setup on the product control panel.
  • Press the right arrow button until Print Report appears on the control panel display, and then press OK .
  • Press the right arrow button until Fax Confirmation appears on the control panel display, and then press OK .
  • Press the right arrow button to select the appropriate option (listed in the following table), and then press OK .
Sep 25, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
Received confirmation
Sent confirmation reports are available within the fax machine.
Theoretically if the fax has been successfully sent, it should be successfully received on the other end as well.
But unfortunately there is no confirmation for successful receipts, unless you are using IP based fax transfer.
Mar 31, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their own...so your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Fax Transmission Reports
You should have a "setup" button. Press that and go to "fax" set up. You can select your options from there. Your options should include the ability to receive a receipt for all transmissions, or none, or just for failed transmissions. Also, you mentioned you "inherited" the machine. I'd suggest going to hp's website to update the software/drivers. The site is www.hp.com.
Oct 02, 2007 | HP LaserJet 3050 All-In-One Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
173 people viewed this question
Ben Johnson
