Question about Ducane Meridian MDBQ-30 Grill
Grill will not light
I was grilling on a very humid evening (we were having a tropical storm pass by. The grill went out and now will not light
    Problem Solver:
  • 18 Answers
If it's got gas going to it, check the spark electrodes make sure they, or the wires going to then are not touching aky metal. I doubt the storm had anything to do with your problem.
Posted on Sep 10, 2008
Flames coming out of front of two burner on Charbroil Commercial grill
you have a gas leak on the control knobs soap test to see where the leak is. use washing up liquid and water to check for leaks .
Jul 24, 2016 | Grilling
My outdoor Built in BBQ has a lot of rust, but NOT rusted through. I want to get rid of the rust and then treat it and paint it to prevent further rust
If the rust is on the exterior of the grill, remove the rust using a steel bristle brush and then smooth it down with sand paper.Spray a light coating of High Temperature Grill Paint (you can find it at most hardware stores and home centers) This first light coat, will act as the primer coat. After it thoroughly dries, apply 2 more light finish coats allowing each coat to dry, before applying the next coat.
Based on the air temperature and the humidity level in your area, wait at least 3 days before using the grill.
If the rust is on the inside of the grill, just removing the rust will generally take care of it As most grill tubs are made of cast aluminum and don't require painting. What may appear to be rust is flaked on food and grease. In which case, a plastic putty knife and a roll of paper towel will take care of it.
And finally, investing in a grill head cover (made for built-in grills), will really help in not allowing the grill to rust again.
Hope this helped you and Happy Grilling!!
Jul 14, 2011 | Grilling
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
Need 4 bunner tubes and 2 crossover tubes for summit platinum
Call Weber direct 1-800-GRILL-OUT (1-800-474-5568).
I have found them VERY helpful and several times THEY told ME it was still under warranty and the new parts cost me nothing. Even when a wind storm blew my BBQ off the deck they covered the repairs
Mar 13, 2010 | Weber Summit Platinum D4 Grill
I have an lg dehumidifier LHD 45EL. The humidity reading reads 15% higher than a stand alone humidistat and the unit will go on for a short time even though the set humidity level is 70%. What gives?
Possibly the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | LG Dehumidifiers
Coal starts dying out the moment I put the Grill
even with all the vents open the air is restricted with the top on. This is what makes the kettle such a remarkable cooking machine. If you wish to grill then leave the lid off and cook directly over the coals, if you are grilling a thicker cut of meat such as a 1 1/2" thick porterhouse you might want to put the lid on for a while to more or less bake or broil the meat without blackening the surface of the meat and to achieve the desired internal doneness of the cut. you can also stack your briquettes/lump to one side and put the lid on so the exhaust is opposite to create a non direct cooking environment for cuts such as butts, ribs, briskets, whole chickens etc
Sep 12, 2009 | Weber One Touch Silver Charcoal Grill
Grill will not light, i have gas in tank but can not hear gas
If your bottle is full , could be the regulator or spiders have webbed up the lines , check theses potential problems. Hopefully this helps you out.
Jul 26, 2009 | Weber Genesis Gold B Grill
Gas grill overheated
I might have an Idea to what happened. All grills have a drip pan, most all new grills have a drain for grease that falls from our savory meats. Well, if, (not saying that you haven't) but if, you have not cleaned the drip pan, there is still grease left over that gets absorbed by food droppings. IF this is the case, you had a ticking time bomb of a grease fire. The grill did not overheat, the grease caught fire. You said your grill was a year old; so the regulator did not go full blast and when they do go bad they do not let gas pass through.
Not trying to preach to no one because I have done it myself, never leave your gas grill on and unattended. I hate to say it but even the owners manual says it.
I hope I did not come off the wrong way and I hope this might give you an idea/thought of what happened.
Sep 26, 2008 | Thermos Stainless Steel Gas Grill
Ducane Meridian MDBQ-30 Grill Logo
102 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
