Question about Amana ALW880WH Top Load Washer
Amana washing machine
Getting oil in the tub and on clothes
  • Anonymous Mar 12, 2014
    Amana wash machine puts holes in my clothes
Replace spin belt
Posted on Aug 08, 2007
    Scholar:
  • 124 Answers
It is likely to be the transmission but you should be able to tell for sure by putting clean paper under it to determine where the oil is coming from. in case transmission in truely the problem, getting it fixed should be relativly easy, but it also depends on the exact model (I dont know this specific model unfortunatly). if you are not very handy, it might give you some trouble, plus it isnt cheap at all, so if it is a cheap washer, I would get a new one. anyways, if you still wanna do it by yourself, and you made sure this is a transmision thing, you can buy a new part (make sure you get a repair manual with it). good luck
Posted on Mar 21, 2006
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Amana washer "goo" on clothes?
Ann, these Amana's are the mother of all washers to change out the seal and bearings. It's possible you just have a lot of gunk built up on the inside of the basket from years of washing. I would not put a cent into it. You are better off getting a new direct drive washer. Catriver...post back.
Posted on Oct 08, 2006
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
SOURCE: Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Posted on Feb 26, 2010
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Worth fixing dryer that is getting oil spots on clothes model mah5500bwq
This machine has no oil in the tub assembly. Over a period of time and using cold water washes body oil, dirt and undissolved detergents and fabric softener will accumulate at the water line on the inner wall of the outer tub. After the gunk builds up thick enough parts of it will break loose at times when using hot water and then get on the clothes.
Nov 03, 2012 | Maytag Washing Machines
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Amana Washing Machines
Noisey spin
The noise is from the transmission and is usually pretty expensive. You really are better off getting a new washing machine.
Feb 24, 2010 | Amana DLW330RA Top Load Washer
Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Sep 27, 2009 | Whirlpool LSN1000LW Top Load Washer
I have an Amana ALW880QAW that is putting yellow spots on the clothes.
possible you have older machine with rust in the tub
broader spots to allout dingy colors if clothes set in washer
or have well water ...that can make a difference
Aug 24, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water still in tub
The splash ring on top of the basket has water in it for balance. As long as you don't see water in the bottom and the clothes are spinning correctly, then there shouldn't be a problem.
Mar 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Amana ALW880WH Top Load Washer Logo
624 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
