Pioneer DEH-P840MP CD Player
Problem for Pioneer DEH-P840MP CD Player
Pioneer DEH-PB40MP No Power
By polliwog on Mar 18, 2006
I have had this deck in my Truck for about 6 months
with no problems. Problem now is no power,no Display. (unit usually powered up and opened the front panel if I left it that way.
There is power to the plugin (yellow wire)and a good ground (Black Wire) I also made sure I plugged in the antenna each time I checked for power up.
I tried wiggling the plug. Still nothing.
Popped the display panel off and cleaned the contacts, nothing. I also tried pushing in the pin prick button in the front of the display panel. (I was told this might be a restet button) I have no manual or warranty for this. Is there an internal fuse on these that I can replace or have replaced?
I first noticed it did not power up when I started the truck one day. I always turn on some music first thing. It did not smoke or "pop" or anything, just no power.
Please Help,
Paul
Best Solution
posted on Mar 21, 2006
Helpful)
hendrix
Rank: Wiz
Rating: 77%, 744 votes
hey, indeed this sounds like a couple of fuses gone bad. I dont know this accurate model, but it shouldnt work any diffrent.
Anyway, with the stereo UNPLUGGED remove the covers and inspect inside, especially in the vicinity of the power transformer. The fuses may be glass cylinders with metal caps. There are other types, but the only ones you should probably try to mess with are the glass type, usually about 5/8" long by 1/8" wide. They should ONLY be replaced with the same type. Somewhere on the cap will
read something like 3A, 4A, etc. This is the ampere rating. Replace only with same rating. It is foolish and dangerous to just go out and grab whatever fuse is laying in your car's glove-box, for example.
There may be a couple fuses. As I said, there are other types of fusible devices, but they would require a tester and some limited knowledge of electronics to test. The glass-bodied fuses can usually be seen to be either good or bad by looking at the filament inside.
Was this helpful?
Yes
No
Solution #2
posted on Jul 08, 2008
Not Rated)
bants
Rank: Guru
Rating: 85%, 83 votes
have u checked the trucks electric fuses in the fusebox ?check for ACCESSORIES fuses.
then go for any further experimentation.
as for the RESET BUTTON,use it after your stereo comes to life .
i do hope this solution helps
Was this helpful?
Yes
No
Popular Solutions for Pioneer DEH-P840MP CD Player
Questions and Unsolved Problems for Pioneer DEH-P840MP CD Player
Do you recommend Pioneer DEH-P840MP CD Player?
Answer
Answer
I have a Kenwood KDC7016 head unit. I am trying to connect my ipod. I have been told to disconnect... (More)
Answer
power acoustik ptid 7002nr where sdoes the sd card go
Answer
Years ago I pushed a button to lower the front panel and get access to the rear panel. Once the... (More)
Answer
My pioneer head unit thinks that i have subs to the rear and not rear speakers, well at least thats... (More)
Answer
Hi I have the pioneer deh p840mp / p850mp model. Ive replaced the ribbon cable twice because they... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
