Question about Dryers
Kenmore dryer dryer was not staying on with on and off switch. I bought a new on and off switch but it's doing the same thing. The dryer will work if I but weight against the on and off switch.
  • 550 Answers
Switch was not at fault
the switch supplies a momentary current to a relay that then latches to supply the current to the heater and moto until disconnected by the door switch or timer
too much current for a switch.
The relay has either disconnected the wire from its latching circuit or failed internally.
trace the wires from the switch to the relay, something like this kenmore dryer - 2162bd6.jpgmay not be transparent, but will likely be the first device downstream from the button
If any wires are loose, refit them. else replace relay. There are very few relays, common to many dryer models, the local parts guy will have one, if not marked kenmore, then Frigidaire or GE
make certain when repacing that each cable is set on the terminal that it was removed from.
Posted on Sep 09, 2008
Bought a new dryer timer. The recommended part for Kenmore dryer model 110.97281100 is WP3398190. The old timer model is M460-G and 3391658. Things do not line up exactly.
From your description, it seems you do not have an exact replacement. See what www.searspartsdirect.com has to say. Don't be surprised if you get several different answers.
Nov 07, 2016 | Kenmore Dryers
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
I think my dryer finally stoped
Inspect the start switch and the door pressure switch as well. if both switches check out OK, replace the timer/control device.
Jun 03, 2009 | Kenmore 700 6972 Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
