Question about ASUS K8V-MX Motherboard
Fpanel Hi, I have removed all leads in the front panel control part of the motherboard in order to switch a hard disk drive. I thought I could remember how to put them back but now I cannot start up the computer. Please could you tell me which colours go where? I have the online manual available but it is meaningless to me since I don't know which cables control which parts of the front panel. Thanks.
  • unreal_class Sep 09, 2008
    thanks mike - got it to work! that was worrying for a while!!
    President:
  • 2,351 Answers
Hi, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & Red is connected to + positive pin. Go to page 1-26 & zoom in. The case's connectors should be marked closely like the on-line manual. All these case LED's use 5volts DC. If you make a boo-boo (place the connector on back-wards, don't freak out). You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. I know it’s a tight fit, so start with the power switch & test it once connected.
You should be just fine.
Good luck unreal_class!
Mike
Posted on Sep 09, 2008
Where can i connect the power sw connector to the f panel pci express
The cable coming from the power button on the front/top of the case would plug into FPanel port. Not sure where you are seeing sata 2 but that's for hard drives and roms. Check your motherboard manual or download one from the manufactures website to be sure on where you need to connect this.
Aug 18, 2014 | Computers & Internet
LOOKING ONLINE, COMPUTER FREEZED SO I SWITCHED IT OFF BY UNPLUGGING IT, WHEN I SWITCHED IT BACK ON IT POWERS UP THE MOTHERBOARD, THE FANS START, THE DISK DRIVES OPENS BUT NO BEEPS AND NO IMAGE ON SCREEN....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 29, 2011 | Biostar K8M800-M7A Motherboard
Every time i switch on my s70 on the screen comes fatat application error Help.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
you could run the check disk utility
hope this helps
hope this helps
Jan 27, 2011 | Computers & Internet
Hard disk common problems
first up
also
hope this helps
Jan 24, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
I have a gigabyte ga 81865gme775 mother board, can you give me the front pannel connection details
hello jknr09
my name is ausi
i can not find your motherboard on gigabyte web site. however the boards nowadays are standard as far as front panel header goes.
on gigabyte mother board you will see the hedae as two rows of pins like this.
the bottom row first 4 pins are the speaker pins. the next single pin is void the next two are reset switch. the last two are hard disk lead.
the top row first two pins are message lead (usually not used). the next two pins are power switch exactly opposite the reset switch.
the power lead connection on gigabyte boards are a three pin header next to the front panel header.
hopefully this is helpful.
please vote for me
Jan 20, 2011 | Intel Motherboard
It has a front lcd temp indicator and a bunch of wires to connect to the mother board. I have no manual and I am confused
If you can describe the problem by listing the wore colours and any lettering on them, I might be able to help. Also the motherboard you are trying to connect to as I need to find out the Fpanel pinout
To help you initially.
1.) Wires that are grouped in a series of Red Green white and black are commonly the USB connectors which will go to the uSB headers.
2.) Black and white wire coupled together as a 2 pin is usually the power switch which goes to the Fpanel header
3.) Any wires that appear to be fused in a plastic type sheath are sensor wires.
I'd first try tracing the source of the wires and see where they lead on the front panel, note these down and repost
Jan 01, 2011 | ASUS Computers & Internet
Samsung hdd322jc not recognise !
A bad/faulty lead can lead to a computer not recognizing a hard drive and any other connected devices a
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
also you might try control panel administrive tools computer mangement device manager scroll to disk drives + to expand if you see your drive right click update driver,uninstall or select properties trobleshoot,select the driver where you can update driver,rollback driver or uninstall remembering to reinstall the driver after it is uninstalled
hope this helps
Nov 11, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
FPANEL CONNECTION
Front panel connection are the power on, power led, reset and hard disk drive led. Makes sure all those connections are properly set up or else you will not get your computer on. If your motherboard is color coded then it will be much easier for you on how to that. Just follow the instructions using the motherboard manual on how to connect properly those connections. Else if you are not sure, I recommend you get a qualified person who can do that for you.
Hope this could be valuable information for you..:-) Thanks..
Dec 25, 2009 | ASUS K8N-VM Motherboard
915P M3 motherboard: no manual for front panel pin out? Help please :) ty
Most motherboards have the same pin-out- here you go (see if I can make this work)
power led
v
v power switch
v v
|x x| |x x| o <-key, no pin
|x x| |x x| x <-not used
^ reset switch
HDD led
http://www.intel.com/support/motherboards/desktop/sb/img/fpanel.jpg
Apr 30, 2009 | Computers & Internet
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
ASUS K8V-MX Motherboard Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
